Old 09-06-2009, 02:43 PM   #1
68fixeruper
68fixeruper's Avatar
Fuel system on 5.3
Ok so ive looked around and ive been debating the best route to setup my fuel system. Ive never done anything like this so i just want to make sure everythings right.
parts i know i need are
fpr corvette 99-2003
inline pump - walbro 255 (gsl392) - i think
fuel lines - the pump is 5/16 so can i run fuel injection hose or do i need to do hard lines.
last a gas tank which i think ill be running either a blazer tank or summit tank
i know i can get the disconnects for the fpr which are. 730-4927 and 730-4926 from napa.
68fixeruper is offline   Reply With Quote
Old 09-06-2009, 10:44 PM   #2
68fixeruper
Re: Fuel system on 5.3
does anyone have a easy step to hooking this stuff up?
Old 09-07-2009, 08:33 AM   #3
eagleuh1
eagleuh1's Avatar
I did a 96 S10 Blazer with 5.3 and used stock tank and pump, Corvette FPR, compression fittings like swagelock from the NAPA adapters for FPR to new hardline up to engine, then Summit stainless braided hose and compession fitting to quick disconnect on the intake fuel line. Works good, no leaks and not too expensive. Good luck. Jim
eagleuh1 is offline   Reply With Quote
Old 09-07-2009, 11:41 AM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
im using 1' of fuel injection hose to connect the hardlines to the tank/pump. and compression fittings fom hardlines to the hardlines coming off of the fuel rail.
i compression fitting leaked before i started engine. replaced fitting so far so good, but i do still carry a fire extinguisher just in case.
i assume youre not using the truck intake with the built in fpr?
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 09-07-2009, 11:52 AM   #5
eagleuh1
eagleuh1's Avatar
No, Mine was a 2005 Suburban 5.3 with electronic throttle body. Used the original gas tank from S10 Blazer with original in tank pump. The hard line from pump to original fuel filter I cut and used a Swagelock compression fitting to attach the quick connect adapter from Napa. This goes into the Corvette FPR filter inlet. The return I attached the same way to the cut return line that was on the S10 Blazer from the intake pressure regulator on the old engine, just cut it next to the new FPR. The supply from the Corvette FPR to the 5.3 Truck intake fuel rail, I attached the NAPA quick connect adapter to the FPR, then to the cut fuel line on the S10 Blazer using another swagelock compression fitting. Then from the fuel line at the engine bay used summit Compression AN fitting to Braided fuel line to a quick release AN fitting adapter to the fuel rail. Works great, no leaks.
Old 09-07-2009, 07:32 PM   #6
68fixeruper
ya i am using the truck intake i guess it has a fpr on it.
Old 09-08-2009, 08:25 AM   #7
eagleuh1
eagleuh1's Avatar
It depends on what year truck intake. Mine was a 2005 and it does not have the FPR on the intake. What year is yours?
Old 09-08-2009, 03:55 PM   #8
68fixeruper
2001
Old 09-09-2009, 07:55 AM   #9
eagleuh1
eagleuh1's Avatar
I'd guess it has the FPR on the intake if there's two fuel lines coming off the intake. Not for sure on that year though. Sorry.
Old 09-09-2009, 08:51 AM   #10
68fixeruper
Yup I have to lines from the intake
