misshape grape
if you had rear drum brakes, and wanted rear disc..
what would be the best way of doing so?
Any of these rear brake conversion kits good?
Don't you just love rumors? I always find out stuff about myself that I had no idea I even did.. |
Re: if you had rear drum brakes, and wanted rear disc..
x2 plus with these kits what happens when the part wear out(pads,drums ) where do you replace them at
search for "rear discs" on here there is should be tons of info.
misshape grape
search no workie....
except the google search link up there where you have to wade through everything. oh well, I suppose I'll figure it out.
'87
If I remember correctly, a member on here purchased a kit from here http://www.blackbirdscustomtrucks.com/ he had a good experience with his kit.
the blackbirds kit is what i got... i am very happy with the looks, cost, and the fact that everything is factory GM. very good and stand up guy to deal with too. dont know about the performance yet but its gotta be better right??
![]() too bad that search isnt working for ya. theres a ton of info and things you should know and take into consideration depending on budget and expectations...
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() Last edited by menace121978; 09-06-2009 at 09:12 PM. |
Happy to be here
![]() Join Date: Mar 2000
Do you just want to add rear discs, or do you want bigger than stock?
There are several kits out there that offer a mounting bracket to put a single piston caliper on a standard 11.50-12.00 rotor. If you want to step up to a 13" rotor the price starts to climb. Here's a couple posts on the subject- McGaughys rear big brake kit arrived
sorry, i thought search was up again
![]() I think glock35ipsc was making brackets at one time and Captainfab sells them also http://67-72chevytrucks.com/vboard/s...d.php?t=339280 http://67-72chevytrucks.com/vboard/s...d.php?t=334885 and Ken....was that quote in your sig directed at you? ![]()
#10 | |
Yeah, that came form a post in the photoshop forum, where he asked to have some different wheels put on his truck.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
![]() some guys are never happy ![]()
Happy to be here
#13 |
couldnt you swap later truck whole rear even there both 10 bolts or 14 bolt depending on what weight
#14 |
Superbad
I did mine with 1995 Dodge 1/2 ton 4X4 front rotors that I redrilled, stock front calipers, pads, rubber brake lines & Speedway Motors weld-on caliper brackets for under $200. I don't have a parking brake but this truck will be bagged & laying frame so that was not a concern for me.
#15 | |
misshape grape
Thanks for the links and suggestions, it's greatly appreciated!
