Old 09-06-2009, 07:01 PM   #1
pdr510
Junior Member
pdr510's Avatar
Need some advice
I have a 454 out of a '97 3/4 ton truck that I have just finished rebuilding. I running roller rockers and will not be able to use short valve covers. The dilemma is the tall valve covers will not clear the ac compressor bracket. So should I go with an old school V-belt set up or modify the ac bracket were there would only be 3 out of the 4 bolts holding the compressor to the bracket. I have attached some pics that I found online to give you an idea of what I am talking about. By the way, I am going to be running a carb not the efi setup that you see in the pics.
1970 C-10 Fleet Side
Gen IV 6.0 with 4L80E
pdr510 is offline   Reply With Quote
Old 09-06-2009, 07:19 PM   #2
Wideopenracing15
Wideopenracing15's Avatar
Re: Need some advice
I see nothing wrong with just going with a v belt set up.
Wideopenracing15 is offline   Reply With Quote
Old 09-06-2009, 07:34 PM   #3
BarryB
BarryB's Avatar
I'd modify the bracket, be alot cheaper and more dependable IMO.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 09-06-2009, 07:50 PM   #4
big_al_71
big_al_71's Avatar
I would also modify the bracket alot easier...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-06-2009, 10:05 PM   #5
AusMarty
I had a similar problem on my 55 chevy, the rocker cover was too close to the brake booster so I took a slice out of the cover and welded it back up
AusMarty is offline   Reply With Quote
Old 09-07-2009, 01:10 PM   #6
pdr510
Junior Member
pdr510's Avatar
I agree modifying the bracket is going to be the easiest. Is there anyone here running the 454 vortec brackets? I would love to see some pics.
