WTB: 67-72 a/c brackets
I'm looking for a 67-72 sbc a/c bracket system for mounting the a/c compressor on the pass side of the engine. I'm in the Dallas TX area, shipping ZIP 75041.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-06-2009 at 09:27 PM. |
Member #1049
Re: WTB: 67-72 a/c brackets
![]() Join Date: Jan 2009
If you don't take the set on e-bay, I have a '72 Super I'm parting out, I'll take brackets off it for you.
Tom Jones Havelock, NC (252) 670 6039 |
I do prefer to do business w/board members whenever possible. How much would you want for them?
Figures.... I searched the past couple of days. This made me realize I was checking in the 'vintage parts' section only & didn't look around in just the cars/trucks parts.
Thanks!
Do you want to use them with cast iron manifolds or headers? Each application has slightly different back brackets.
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) Last edited by Primered_69; 09-06-2009 at 09:45 PM. |
As do I!! $125.00 work for you? The truck isn't at my house, please don't send money yet let me take them off and ensure they are all there and in a condition I would want to buy. The truck is just as it was when it was built plus a little rust!! You need anything else, any small parts I can chunk in a box for you to help your project along?
Tom I can |
Doing aftermarket Ram-Horns (if they'll fit). 3/4 length Chevelle headers if not.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-06-2009 at 09:45 PM. |
The Super has the original manifolds.
Do you know what's different specifically? I would have thought they were all set-up for manifolds & used spacers if headers were swapped in place.
Bump. Hoping someone local might have these before I move forward & commit.
Good luck!
#13 |
Thanks. Until I can confirm the discrepancy on the possible differences, I'm going to try & find some locally so I can actually look @ them. I'll follow-up if nothing local plays out.
#14 |
After looking at all of the brackets I see what the difference will be. The points where that lower, cast, bracket attaches to the manifold is about ¾ of an inch out from where the header flange would be. It mounts to the first and third flange bolt. As I see it looking at the truck beside it with headers, you'll need spacers to support that bracket. If I can help you let me know.
Tom |
#15 | |
Now I need to see some installed to determine if I can so something similar. I'm going to try & talk to a local guy to take a peek under his hood to get a better idea.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-07-2009 at 10:43 AM. |
#16 |
If you have a cell phone that can recieve picture texts I can send you the ways they are different.
I have a set of each... may be interested in parting with one set. You wouldn't have any extra 4 core radiators sitting around for trade?
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) |
#17 |
Junior Member
I am about an hour and 15 minutes East from Town East Mall and they are still on the truck. I think I am going to part the whole truck.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
#18 |
As a matter of fact I do..... Brand spankin new 4-row that was intended for my Beater. Straight up swap for all required brackets?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-09-2009 at 12:45 AM. |
