Old 09-06-2009, 09:04 PM   #1
drewfever1020
who has posi?
what do i need for my rear end after i install my posi?
drewfever1020 is offline   Reply With Quote
Old 09-06-2009, 09:47 PM   #2
powell72
powell72's Avatar
Re: who has posi?
I run regular gear oil and GM "limited slip axle lubricant additive", part #1052358.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 09-06-2009, 10:49 PM   #3
drewfever1020
Re: who has posi?
i mean am i gonna need like a traction bar or somthing like that?
Old 09-06-2009, 11:15 PM   #4
truckster
truckster's Avatar
Re: who has posi?
You need to give a lot more information to get an accurate answer to a question like that. What engine/trans/gear ratio? 2wd or 4WD? Coils or leafs?
If you're running a stock engine on a 2WD with coils, I suspect you'll fine your stock suspension does a pretty good job of letting you hook up with the posi.
truckster is offline   Reply With Quote
Old 09-06-2009, 11:18 PM   #5
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: who has posi?
You are only going to have a chance of axle wrap with a leaf rear end. The coil one won't budge. There was a guy on Pass Time running in the 9's with the 2 link setup. The main thing you will need is a video camera so you can post your burnout. It is required or you will be banned! lol
prostreetC-10 is offline   Reply With Quote
Old 09-06-2009, 11:20 PM   #6
mr48chev
mr48chev's Avatar
Re: who has posi?
You shouldn't need anything unless you intend to race the truck. Then the standard mods to help it hook up apply. If it is a coil spring truck there isn't much if anything left to do. A leaf spring truck may need some sort of traction bar setup if you get wheel hop on launch but that would take some serious horsepower in most cases.
Old 09-06-2009, 11:23 PM   #7
BossHogg69
motor exploder
BossHogg69's Avatar
Re: who has posi?
Originally Posted by prostreetC-10 View Post
There was a guy on Pass Time running in the 9's with the 2 link setup.!
wasn't that 'djracer'? I saw that episode too, that truck left so hard it scared the host of the show when he took off!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 09-07-2009, 07:24 AM   #8
Re: who has posi?
My k2500 has posi with those leafs.Although they are stiffer than 1/2t (if that`s what you have) i don`t have any wheel hop or notice axle wrap if there is any.I run 12.50/33s and chirp them when I hit 2nd hard.I don`t do burnouts with it.It will chirp pulling off hard,though.I`m prolly right about at 275 horses.
Old 09-07-2009, 08:08 AM   #9
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Re: who has posi?
I have a posi! and I posi-tivly love it
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
