09-06-2009, 10:24 PM | #1 |
frame questions??
Removed the bed from my truck this weekend and was not happy to find what I found!!!!! My question is has anyone ever sectioned in frame parts due to rust?? My problem is found just in the area where the front spring perch is for the rear leaf spring, the rest of the frame is in SOLID shape I would like to just replace that part of the frame if possible. Does any one know what type of steel is a frame made out of, my old man says they are made from spring steel, is that correct?? Does anyone have or know of a parts frame or has a frame for there donor vehicle they would be willing to cut up?? I'm in a real jamb now an not real sure where to go from here, suggestions??? Dont forget I live in the Northeast an finding a non-rusted frame is not easily achievable!!! I can post pics if need be. THANKS
Once a Marine Always a Marine OOH-RAH GM Fanatic 1982 K20 4" Rancho lift 350cid, edelbrock performer intake 1405 carb, hedman headers, TH350, " Wheres the MUD!!!!!!!!!!" 1986 c30 camper special 454, th400 (for sale) 1984 K10 Big Ten (project) needs motor 1984 C10 355, 700r4, (project) needs shortbox bed |
09-07-2009, 11:54 AM | #2 |
Re: frame questions??
Here are some pics from the rust.
09-07-2009, 01:52 PM | #3 |
Dually Pride
hell thats nothing, at least the pics dont make it look like much, i wouldn't worry about it. I've seen ALOT worse on trucks that haul big loads and never have an issue
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually '94 Ford Ranger |
09-07-2009, 02:01 PM | #4 |
yea i wouldnt think twice about that. just clean it real good and paint it.
09-07-2009, 02:06 PM | #5 |
I have car A.D.D.
I had pictured ALOT worse. Like, 'holes in it kind of bad.' Like said above, clean it, seal it off, and paint it. Thats not too bad looking at all.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
09-07-2009, 03:58 PM | #6 |
please keep classifieds in the classified section
09-09-2009, 02:04 PM | #7 |
Still no luck finding any frame parts without getting a whole one, anyone have a a frame they've cut up or will be cutting up??
09-09-2009, 04:10 PM | #8 |
how much of the frame do you want. i have one i can cut a section out of for you. i'll look tonight to see where i cut it off at, and take a photo for you.
09-09-2009, 04:28 PM | #9 |
Superbad
Yeah that frame looks kinda bad, I would replace it if you could get a new frame. FYI, frames are made out of mild steel, if they were made of spring steel you would have a hell of a time cutting them with a saw blade, like you might do to do a frame "Z", monster notch or C-notch.
09-09-2009, 05:56 PM | #10 |
Have you thought about bolting/ welding a reinforceing plate on the rust effected areas?
***My 84 short bed build up***** http://67-72chevytrucks.com/vboard/s...68#post3481968 |
09-09-2009, 06:14 PM | #11 |
Catchy title goes here..
09-09-2009, 06:17 PM | #12 |
Dually Pride
if youre that worried about it, just weld on some extra plate steel to the area
09-10-2009, 11:21 AM | #13 |
I would bolt in a new plate inside the existing frame and space some 1" welds around the plate. I think this would be a better fix for this areaof the frame.
I can still count my vehicles on two... wait three hands. |
