Old 09-07-2009, 06:48 AM   #1
HarrisonTX
1969 3/4 front disc conversion ?'s
I hate posting a commonly asked question.
Whenever i search, all just see 1/2 ton conversions using 3/4 ton 73+ parts.
So.. My '69 custom/camper has terrible 4 wheel drums.
Is there a simple bolt on conversion using factory parts from a donor disc brake chevy?
simple: will 73-+ 3/4 ton parts bolt up
'69 custom/camper
'74 260z 302 chevy/tko500 swap in progrss
'79 Malibu 355 all forged 4 speed car.
'86 k5 blazer
'06 Duramax
HarrisonTX is offline   Reply With Quote
Old 09-07-2009, 12:07 PM   #2
2tons of fun
Re: 1969 3/4 front disc conversion ?'s
yup,
you will have to drill one hole in each side of the frame if you want to save time by doing the entire crossmember/suspension swap.
i swap to the newer motor mounts when i did mine and it pushed my motor back 1" so you will have to redrill the crossmember for the tranny if you do that.
2tons of fun is offline   Reply With Quote
Old 09-07-2009, 12:39 PM   #3
Castiron9
72 LONGHORN OWNER
Castiron9's Avatar
Here's a picture of my current project.1970 one ton dually.I bought the complete front cross member out of a 1984 one ton.Swapped right on and basically had to drill a couple of holes.I should have it running this week.....
72-SUPER CHEYENNE/20 LONGHORN
70-C/30 DUALLY
Castiron9 is offline   Reply With Quote
Old 09-07-2009, 02:30 PM   #4
2tons of fun
i will be doing it as well, same as above, complete dualy front suspension swap, shouldnt take more than a weekend.
Old 09-07-2009, 02:50 PM   #5
HarrisonTX
Sweet! pics too. Thanks guys
So, since the motor mounts bolt to the frame, i can keep the motor in there, right? A lift would help a bunch it looks like.
I bet i can get the parts for cheap from a junkyard. Thanks guys.
Do some of the holes line up, to better aide me in the drillin of the new ones?
'69 custom/camper
'86 k5 blazer
'06 Duramax
Old 09-08-2009, 12:36 AM   #6
2tons of fun
all of the holes will line up except the top front hole on the upper a arm bracket, you can install the entier clip then drill the hole, you cant screw it up.
search up trkklr77, he did a good pic thread on the swap.
you will most likely need to yank the motor because the motor mounts bolt to the frame and the cross and the weight of the motor will pull and mess with all kinds of stuff when un supported.
Old 09-08-2009, 06:53 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Since I don't have an overhead shop hoist, to keep from pulling the engine when swapping crossmembers, I cut a board the right length to sit on the hood lip on top of the fenders. It's a very strong area of the fender. Set the board on that lip and use a ratchet strap to hold the engine up while you remove the two bottom engine stand bolts and crossmember. This keep you from having the engine hoist legs in your way under the truck or a jack under the oil pan.
