09-07-2009, 09:50 AM | #1 |
Attn: Wheel and Tire Pros
I am currently building a 71 C10, I will be running Foose Injectors, 20X12 in the rear and 18X8 up front. My question is backspacing. The rear is bagged and C notchec with a 3" mini tub. The front has a Scotts Rod Shop IFS with rack and pinion and McCaughey's 13" big brake kit. No bags, coil overs and dropped spindles. The front track measured from the face of the rotors is 63". Im pretty sure I can get away with running a 335/35 on the back on a 20X12 with 8.5" of back spacing. But the front is where Im stumped. 18X8 with 4.5 back spacing "should" work but I really dont need a $2000. set of end tables. WHat do you guys think?
You can see pics here at my hub garage. http://http://www.hubgarage.com/mygarage If the link doesnt work, go to Hubgarage.com and searh JMC Autoworx |
09-07-2009, 10:08 AM | #2 |
Re: Attn: Wheel and Tire Pros
On a stock width front i run 4 3/4 back space and its perfect I ran a 4 1/2 first and it rubbed the inner fender well lip when aired down . On a 20 by 12 with 8 inches of back spacing you must have a wide rear end I run 10s with three and they are 3/4 of a inch from the inner lip with any reasonable rear end width I would think 5 inches would be close with a 12 inch wheel, Are you measuring your back space from the inside out? Mitch
09-07-2009, 10:23 AM | #3 | |
The front sound good too. The SHR front set-up has a narrowed track width vs. OE 67-72's. Many guys run 8" wheels w/4"bs w/o issue. Your choice of a little more back-spacing coupled w/the slightly narrower track width should again keep the wheels off the fender lips. As w/any big purchase, you really should mock up a known wheel combination & verify that the numbers will work. I used what I know (standard 15x8" 4"bs steel ralley) to do the 'reverse' mathmatics on your proposed combo. Even if it were mine, I would be hanging a wheel & double checking the numbers.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-07-2009 at 10:29 AM. |
09-07-2009, 10:52 AM | #4 |
Wouldnt it look better to have the front wheels with a different offset than the rear looking at it from the front with the math provided above the front and rear would end up 3.5 offset looking at it from the face ? A 12 inch wide rim and a 8 inch wide rim on a 68 thru 72 truck looks nasty with no wheel stager
09-07-2009, 01:18 PM | #5 | |
If you wanted a deeper dish in the rear (which I agree does look better), you'll need a narrower rear end (which would require swapping to a pre-70 housing, narrowing the current rear, or swapping in a shorter housing from a car), or the wheels will need to be closer to the fenderlip (which can compromise how low you can go because of interference).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-07-2009 at 01:19 PM. |
09-07-2009, 01:29 PM | #6 |
I JUST MEASURED FOR some wheels and 4 1/2" back spacing is all that would work no matter where, front or rear.
I BELIEVE IN JOHN 3:16 |
09-07-2009, 01:33 PM | #7 |
What did you measure? Did you take into consideration he listed a different front suspension & the fact that he's got 3" mini-tubs? That makes a difference on what works & where.
09-07-2009, 02:21 PM | #8 |
Scoti correct a 70 and up the rear and front are the same width i did see he has has a narrowed front of approx 1 inch . I would like to see 2 inches narrower in the front and would def. recomend switching to a pre 70 or ford nine inch to fill those tubs up with a deep dish rear wheel. One inch stager will still look straight up.
09-07-2009, 03:12 PM | #9 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-07-2009 at 03:13 PM. |
09-07-2009, 03:18 PM | #10 |
Correct per side....
09-07-2009, 03:34 PM | #11 |
So we agree that a 20x12 with 8.5 and 335/35 will look best for the rear?
For the front, should I go 3.5 bs because of the narrowed front? Or maybe go to a 9" wide wheel to fill up some of the lip on the outside? |
09-07-2009, 03:38 PM | #12 |
Are you basing the front being narrowed 1" off of my measurements or off the Scotts front end? Because I did switch the Scotts spindles over to the McCaugheys spindles and they are MUCH bigger than what the Scotts came with. The 63" measurment is what I have now with the McCaugheys spindles on the truck.
Just making sure we are all on the same page. |
09-07-2009, 06:22 PM | #13 |
67-72 parts collector,…
ipaintem,...
why don't you bolt on a set of 15x8 inch wheels front and rear. (with NO tires) Then get out the tape measure and see where everything fits and looks good. Add 4" to the rear wheels to simulate a 12" wide rim. The 15x8 truck ralleys have a 4" bs,... so you can calculate off of that.
09-07-2009, 08:38 PM | #14 | |
09-07-2009, 08:44 PM | #15 |
Man SCOTI,...
I gotta start reading these threads closer. Ha.
09-07-2009, 09:39 PM | #16 |
resident oilfield trash
You should just run 20s all the way around
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
09-07-2009, 09:45 PM | #17 |
I dont have the bed and fenders on as of yet. I was thinking that at least the rear could be a pretty definite yes or no on what would work.
The front I do have a 15X8 to check for clearance and I will do that tomorrow. thanks |
09-07-2009, 09:47 PM | #18 |
the owner wants 18's and 20's
