Old 09-07-2009, 01:14 PM   #1
truckfan
truckfan's Avatar
sport bumper mounting
can someone tell me if you use the flimsy horizontal plate when mounting a sport bumper off a blazer on a pickup? I always thought that plate was what hid the tailgate hinges. it looks like it will hit the edges of the fenders on a pickup.
i think it may look OK w/o it.
any help/pictures appreciated
1981 Chevy C30 440 Holmes 42K one owner miles
truckfan is offline   Reply With Quote
Old 09-07-2009, 01:51 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: sport bumper mounting
The outer brackets work off the blazer and on the inner brackets are part of the frame on a 73-80 blazer
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 09-07-2009, 05:48 PM   #3
Cherub
Cherub's Avatar
Im running just the outer brackets from a burban.
Cherub is offline   Reply With Quote
Old 09-08-2009, 04:32 PM   #4
northern 85
northern 85's Avatar
The flimsy plates that go on top of the brackets?
northern 85 is offline   Reply With Quote
Old 09-08-2009, 04:44 PM   #5
68 TT
Still plays with trucks
68 TT's Avatar
Same here, bumper & outer brackets from a Suburban.
I planned on making some inner brackets that would clear my trailer hitch and spare tire.
68 TT is offline   Reply With Quote
Old 09-08-2009, 04:47 PM   #6
truckfan
truckfan's Avatar
yes i understand i need inner brackets made or purchased for a pickup. this is the flimsy piece that goes on top and lies flat over the brackets. looks like on a pickup, the tailgate swings down into it. i left it off and it looks good
Old 09-08-2009, 09:57 PM   #7
Nukes16
Nukes16's Avatar
I bought the bumper mounting bracket kit from LMC. It was great until I installed the smooth bumper and realized that it was too far away from the back of the truck. I then had to hack and inch and a half out of the new brackets. The ones that go straight back from the frame are easy, but the angled ones really suck because you have to cut them on an angle so that you lose an inch and a half front to back but don't lose anything side to side because the holes have to line up!...If that makes any sense to you?
Nukes16 is offline   Reply With Quote
Old 09-09-2009, 08:55 AM   #8
Jonboy
Slots go on anything!
On pickups with a sport bumper, the flimsy plate you are talking about is two pieces, one for each side. They are only about 8" long, just enough to cover the brackets.
Old 09-09-2009, 11:00 AM   #9
SBTork
Garage wrench
SBTork's Avatar
Yes, they're not structural, the factory called them gravel guards.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 09-09-2009, 11:21 AM   #10
68 TT
68 TT's Avatar
So was the truck sport bumper different than the Suburban bumper in any way?
I put a mid 80's Suburban sport bumper onto my 67 C-10 long ago and when I got my 78 K20 with the nasty step bumper I made the swap.
I had only the outer brackets as the inner's did not fit the 67 so there are extra holes inboard that I filled with spare bolts. It seems pretty flimsy this way so I had planned on building inner brackets to tighten it up a little.
