slammed c20 still 3/4 ton??
i've seen a lot of bagged c20s on here but it seems like everyone converts them to 1/2 tons in the process...anybody drop their 3/4 ton and keep it that way? anyone make drop spindles for the 8 luggers? etc...thanks in advance
![]() Join Date: Nov 2006
Re: slammed c20 still 3/4 ton??
slam equals less payload. might as well go 5 lug components.
I BELIEVE IN JOHN 3:16 |
i have a 1965 c-20 still with 8 lug i just cut the springs and added 1/2 ton dropschocks...it is a bouncy ride if the roads are crap lol
I think you could bag the back of a c20 pretty easily. You would need to pick bags that can handle the intended loads.
I know ECE makes some drop spindles for 3/4 tons, but I'm not sure if they're actually 3/4ton as far as duty rating or if the ball joint holes are just larger so you don't have to switch all that stuff out. Also, I don't know if they'll accept 8 lug rotors or only 5 lug (or if there is a difference as far as the spindle is concerned) |
its all about the +6 inches
one can lower a 3/4 ton on bags and easily maintain capacity
I dont know about slamming it, but someone has the potential of increasing their cargo capacity by adding bags... every single semi truck is "bagged" these days... so if you get the right system in there there is no reason you couldn't work the truck all week and then take it to shows and park it in the weeds all weekend..
we covert ford F550 pickup trucks to full air ride suspension on our "low profile" units. we make a small vacuum trucks to go into underground parking garages etc with low ceailing heights. we get the truck down low enough to fit where you could take a 1/2 ton pickup, and still maintain full weight carrying capability, and no squat when loaded..
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
The static drop is possible I am working on one right now.. Rear axle flip and cut a coil off the front springs.. I am also doing mine without a kit because i gave up trying to locate one. The plan is simple doing it may end up being harder...
- does not need motivation, only money - |
#8 | |
Happy to be here
![]() Join Date: Mar 2000
Shorter springs have more payload.....just a thought to why my ride is crappy
1965 Chevy C-20 slammed 292 L6 TH400 1967 Chevy C-20 on 91 suburban frame project(wife's) 1972 Chevy K-20 Mild 350/th350/np2o5 dd 1952 Ford Customline 2door kustom project 1967 Cadillac Superior Hearse (wife's) 1998 GMC Saffari (wife's dd) |
Big Red - Now its a SWB!
How much did you cut? I cut 1.5 coils (got me ~3") on mine and I didn't notice much of a difference to the ride up front. Out back I pulled 4 leaves and that made the back ride much smoother. And yes it's true, shorter spring have a higher spring rate if all other things are equal.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's Last edited by Jacfourteen; 05-19-2010 at 08:52 PM. |
