Old 09-07-2009, 05:25 PM   #1
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
Question Please help!!!!! Axles?
I have a 70 chevy i am switching to 5 lug. I have got the axles for the rear out of a 71 chevy 2wd. Anyone know what is the length of the 70 axles and is that the only size they come with? I dont have my 70 chevy ones out thats why i wannan know.When you measure where do you measure from-to. I know there both 30 spline. please clarify for me.
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 09-08-2009, 04:19 AM   #2
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: Please help!!!!! Axles?
ttt
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 09-08-2009, 05:47 AM   #3
JimKshortstep4x4
The 70 trucks were equipped with two length axles as it was the change year. Some of the 70 differentials had the same length axles as the 71 and some were 3/4" shorter.
My suggestion would be to pull your axles and compare the lengths. Since you want to go with (5) lugs anyway, you can have your axles drilled while they are out if they are the shorter ones.
Both 70 and 71 12 bolt axles will have 30 splines.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-08-2009, 09:27 AM   #4
jorgensensc
jorgensensc's Avatar
I agree with the above statement. I have some further input though. When I was going to get my 6 lug '68 axles redrilled it was going to cost almost the same as new axles. They said they had to bake them to get rid of all the oils, then weld the old holes, then do something else, etc etc, and they still wouldn't warranty them from failure due to the age.
I ended up buying Moser axles from Summit with new bearings, etc. I think they were a little over 300 shipped to my door. I also had them drill them for both 5 on 5 and 5 on 4 3/4 bolt pattern (I had different intentions at the time). Now I have new axles, bearings, and multiple bolt pattern, which makes buying wheels easier when looking for used.
If the axles you bought are the right length, then great, use them. But I encourage you DO NOT use them if they are longer. Some will say you can use a different backing plate and they will work, however the part of the axle that rides on the bearings will not be the hardened section that is made to do so and can fail.
It wouldn't be fun losing an axle a70 mph on the freeway. Even if you make out okay and your truck isn't damaged, you still have to think about what that free flying axle can do to others in their cars and their families.
Hope this helps a little.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
