09-07-2009, 07:40 PM | #1 |
What is a good height for frame at ride height?
I will be able to lay frame but what is a good cruising height? I tried doing a search but the search function is not working for me. Thanks
09-07-2009, 07:56 PM | #2 |
Re: What is a good height for frame at ride height?
i think most people set up for a 5 inch ride height
09-07-2009, 08:48 PM | #3 |
you dont want to setup your ride height off the frame for these year trucks..
your going to want to set it up off the front suspension crossmember which hangs lower than the frame(unless you Zd the frame or you have a dropmember) but assumind you have done niether of those modifications, you want to set it up off the crossmember.. and my front crossmember is about 3" off the ground, and that might be 5" on the frame but im not sure.
My build thread--http://67-72chevytrucks.com/vboard/s...d.php?t=300333 |
09-08-2009, 11:14 PM | #4 |
I ride about 1in off my frame. If you align your tires at your ride height I'd set it right around 5in off something, either your crossmember, or frame depending on your level of setup like said before. I never aligned mine, since I ride low in town and it varies on the hwy.
09-09-2009, 01:24 AM | #5 | |
Around town/on public roadways @ least 4-5" minimum ride height.
09-16-2009, 05:12 PM | #6 |
On the fast track to nowhere..
Ditto, I set my 88 at 3.5 and drug every time I hit a dip in the road.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
09-17-2009, 11:29 AM | #7 |
AIRBAGPARTS.COM
Here is a good ride height....
09-17-2009, 11:42 AM | #8 |
that is beautiful!!! that is a perfect ride height!!
myspace.com/southtacomaalleyrally |
09-17-2009, 11:49 AM | #9 |
Retiredoldfarttankerguy
Jason - may not be practical but, it's freakin sweet! Sort of depends on your primary cruising plans and how well the road crews in your area keep the azzfalt or railraod tracks- You may want to consider what the PoPo will say?
I'd agree with an alignment at 3-5 off the lowest point - likley the x-member - Happy dragging!
________________________________ Swany Current 67-72 truck projo - #5 of 6 and #1,000,000... of all the other things that keep me from working on it. Fav - local parts shop. They ship world-wide. www.fillingstation.com Last edited by Boomerswany; 09-17-2009 at 11:51 AM. |
09-18-2009, 08:59 PM | #10 |
Superbad
I drove my 94 as low as I could, about 1 - 1 1/2" off the ground. It would occasionally skip off the asphalt & I would have to lift a little not to pick up road reflectors. Good shocks will help with keeping it from bouncing off the asphalt when ridin' low.
