Fabricate till you "puke"
Stripping an anodized grill shell with oven cleaner?
I saw a thread a while back about stripping the anodizing off an alum grill shell with oven cleaner. How well does this work? Also, i would guess it wouldnt be good to leave the stuff on too long.....need advice from anybody who has tried this....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Used to have a truck
Sodium Hydroxide + Aluminum = Bad Mojo
It'll remove the anodizing all right. It'll probably look like hell afterwards though.
No truck :-( |
Active Member
I used the oven cleaner methed on both my trucks with good results. spray it on and let it work awhile till the anodizing will come off with steel wool, time depends on temp, the warmer the quicker. steel wool then rinse and then start over till its all dull, after that sand with 400 grit and finish with 1000 grit then hit the buffing wheel. it will shine great but you'll have to polish it with mothers or something from time to time.
69 Custom/10 454 Turbo 400 and 70 Custom/20 350 Turbo 350, 73 cheyanne C/10 also 69 camaro Z/28 and 85 Iroc Z |
i did mine the same as gashog and it turned out great.
69 chevy short wide box project 70 GMC jimmy project |
That looks nice gashog! That billet grill reaaly sets it off too
1969 Custom 30 wrecker
I've used this method too and it does work. It usually takes 2-3 hits. Do not let it dry on the surface or it's a bear to remove!
Here's a link for a special product to remove annodizing also. I haven't tried it though. http://bluelightning.zoovy.com/product/ADPT
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Thanks for the info guys, the easy off is on the 2nd hit& pretty much took all the anodizing the 1st time! crazyL
Old Skool Club
![]() Join Date: Jun 2001
So, if the EZ-Off will get the anodized finish off (well, that and some elbow grease), would you want to clear-coat it when you get it nice and shiny? Seems like it would be the right thing, but that may not be the case.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
I heard clear coating is a no no you'll regret it , just us mothers wax
#10 | |
Bloo
ive always heard clear coating is bad, but heres mine after 2 months, and it still looks the same after 7
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
Bloo
heres the same grill on the 4x4, i forgot i had this one for a 7 month example
Im not sure how this one will go yet. The old grill has a couple bruised areas that I need to bump & file, then block sand. if I can get it straight enough to polish, I probably will just leave it raw & do the elbow grease from time to time. I have also thought about having it powdercoated....crazyL
