Old 09-08-2009, 05:20 AM   #1
hatzie
Moderator
hatzie's Avatar
73-78 doors directly interchangeable with 79-91
I've read. The door width at the style line of the 73-78 OEM GM doors is 42". This individual also stated that all Aftermarket doors and the OEM 79-91 doors are 1/4" narrower measuring in at 43 3/4".
Is this accurate or BS?
- David H
Old 09-08-2009, 06:08 AM   #2
Number21
Number21's Avatar
Re: 73-78 doors directly interchangeable with 79-91
The only difference I've heard about with the earlier doors is that they don't have provisions for power stuff.
Number21 is offline   Reply With Quote
Old 09-08-2009, 08:32 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Externally the doors are all the same. Internally the doors run 73-76 then 77-91. They will all fit, the early dors don't have provision for power windows. The door panel area is different too.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-09-2009, 03:03 AM   #4
TheSunDanceKid
TheSunDanceKid's Avatar
you guys ever seen the conversion kits they have to change manual windows into autos with out changing regulators and what not ive installed a few sets a while ago there pretty nifty
http://www.slickcar.com/productdetai...ProductID=3277
TheSunDanceKid is offline   Reply With Quote
Old 09-09-2009, 08:46 AM   #5
bigblock73
yeller
bigblock73's Avatar
This is the second time I have heard the 1/4" difference thing...We should have some of the 73-76 guys measure their doors to see if this is true (my doors are 77+...I can measure those).
But long story short, the doors are interchangable as far as bolting them on...just remember the guts and panels changed a little.
bigblock73 is offline   Reply With Quote
Old 09-09-2009, 08:51 AM   #6
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Originally Posted by bigblock73 View Post
...We should have some of the 73-76 guys measure their doors to see if this is true...
I'll measure the ones on the 75 tonight. I just got a set of 74 doors last weekend too. I'll measure those to start some sort of average.
Are we measuring the style line right under the door handle?
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 09-09-2009, 12:57 PM   #7
bigblock73
yeller
bigblock73's Avatar
I would think that would be easiest and most accurate.
Old 09-09-2009, 06:24 PM   #8
xbanone
xbanone's Avatar
41 3/4" on my '76 doors I am pretty sure they are OEM. I also have a few other sets I will check in the 78+ range. I plan to replace the doors on my truck with a set from an '86 Blazer.
1976 K15 Short/Step
1981 C10 short/wide
1994 K1500 ECSB
xbanone is offline   Reply With Quote
Old 09-09-2009, 10:28 PM   #9
Restrorob
The One And Only !!!
Restrorob's Avatar
I got 41 3/4" on my 74 aftermarket doors, Trashed the originals years ago....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 09-11-2009, 06:26 AM   #10
davehatz
My rusty 76 OEM door is 41 3/4" as well. My guess is that the measurements on the 78+ doors will be the same as all the others.
davehatz is offline   Reply With Quote
