Old 09-08-2009, 10:19 AM   #1
Hart_Rod
Hart_Rod's Avatar
Parting 1968 Big Block SWB truck
Matching 402/TH400 + lots of MISC...$600!!!
71 402 motor/TH400 tranny, matching set - $600 (pick up only)
Code Year Model CID HP Trans Comment
TKB 1971 Truck 402 310 400 L-47 10, 20, 30
motor stands and mounts - Sold
distributor (new points/coil) - $30
oil gauge line (outer) - $20
tranny auto crossmember - Sold
heat shield for passenger's fire wall - $25
exhaust manifolds (perfect no cracks) - $100
air cleaner and spacer - $40
4 core radiator - $75
Dual flowmaster (40 series) setup with H-Pipe - $125 (pickup only)
1968 bench seat, great foam and cover - SOLD
1968 auto column - SOLD
** Pulleys and brackets sold to camtoys1 **
Complete p/s setup (pump (no dents), reservoir, pulley) - $225
a/c 9-bracket setup - $275
alt brackets - $125
all 3 pulleys - $100
fan shroud, clutch fan and shift linkage ** SOLD to BB72CHEVTK **
Perfect heat tube (breather to exhaust) - ** SOLD to Sameyrasmea72 **
exhaust heat shield - ** SOLD to Dantip **
67 SWB - ** Sold, thanks Tom! **
tailgate - ** Sold, thanks Tom! **
The cab, front clip and chassis have been sold.
All prices are + shipping (paypallers add 3% for fees)
Hart_Rod is offline   Reply With Quote
Old 09-08-2009, 12:08 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Parting 1968 Big Block SWB truck
OH NO!!!....Bye Bye 50th clone!!!....Sorry to see it go this way
TTT for ya Rob!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 09-08-2009, 12:52 PM   #3
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
side view mirrors with backing plates shipped to 95901?
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 09-08-2009, 01:49 PM   #4
Jbham88
Jbham88's Avatar
What Kind of shape is the tailgate in and would you ship to 39402 might be interested in the rad as well?
1986 GMC 4x4
Jbham88 is offline   Reply With Quote
Old 09-08-2009, 02:31 PM   #5
Hart_Rod
Hart_Rod's Avatar
TTT for ya Rob!!!
It's for the best.
Complete cab, front clip and rolling chassis are already sold.
Outside is great. The inside has some dents and dings. It should be a fairly easy fix. I could stick the tailgate on a Greyhound. It will probably cost $50. Are you sure you don't want to make a trip to Pensacola? It would probably cost you the same. Let me know.
Old 09-08-2009, 02:33 PM   #6
1967chevyswb
1967chevyswb's Avatar
Do you have the big block engine stands. If so how much shipped to 67401. Thanks
1967chevyswb is offline   Reply With Quote
Old 09-08-2009, 02:38 PM   #7
Hart_Rod
Hart_Rod's Avatar
I'll take $150 shipped for the stands AND the motor mounts.
Old 09-08-2009, 02:42 PM   #8
1967chevyswb
Ok I will et you know Thanks
Old 09-08-2009, 06:12 PM   #9
Jbham88
Jbham88's Avatar
Outside is great. The inside has some dents and dings. It should be a fairly easy fix. I could stick the tailgate on a Greyhound. It will probably cost $50. Are you sure you don't want to make a trip to Pensacola? It would probably cost you the same. Let me know.[/QUOTE]
Do you have any pics I plan on linexing the inside of my bed. Wish I had know I was just down there this past weekend
1986 GMC 4x4
Old 09-08-2009, 06:31 PM   #10
Hart_Rod
Hart_Rod's Avatar
Do you have any pics I plan on linexing the inside of my bed. Wish I had know I was just down there this past weekend[/QUOTE]
Do you plan on coming back any time soon? I can hold it for you for a while if you pay for it. I'll take $250 for the gate and the radiator. LMK.
R
Old 09-08-2009, 06:34 PM   #11
Wootdog
Wootdog's Avatar
Hart Rod,
Does the engine and tranny work?
Kerry
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 09-08-2009, 06:37 PM   #12
budder71
what's the story on the BB 402 and tranny ? motor running and complete with intake and carb ? tranny needs ?
budder71 is offline   Reply With Quote
Old 09-08-2009, 06:41 PM   #13
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Wootdog View Post
Hart Rod,
Kerry
The came out of a low mileage truck (87K) but they both need rebuilt. The engine got some water in the intake, but I've had it soaking in diesel since I've had it. I figure even as cores, they are worth what I'm asking. LMK.
Old 09-08-2009, 06:42 PM   #14
Hart_Rod
Hart_Rod's Avatar
It's complete (factory carb and intake), both motor/tranny will need to be rebuilt.
Old 09-08-2009, 06:51 PM   #15
Wootdog
Wootdog's Avatar
I am always a day late and a dollar short. I do need a cab more than anything. And a right 68 fender and a right door. You know the drill.
Kerry
1967 C10
1969 Chevelle
2002 Silverado LT
Old 09-09-2009, 07:48 AM   #16
Hart_Rod
Hart_Rod's Avatar
Kerry
Totally understand Kerry. I'll keep my eye out for a cab, door and fender...
Old 09-09-2009, 09:29 AM   #17
Jbham88
Jbham88's Avatar
Hart
Thanks but i found one a little closer tuesday. I think im going to go with it good luck with your sell
1986 GMC 4x4
Old 09-09-2009, 08:42 PM   #18
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
What condition is the shroud? Are the tabs broken or any cracks?
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 09-09-2009, 09:11 PM   #19
Hart_Rod
Hart_Rod's Avatar
Hart
No worries. Let me know if you change your mind.
No cracks and not broken. Here's some pictures:
Old 09-09-2009, 11:45 PM   #20
Chevy_Man
Tightwad
Chevy_Man's Avatar
Has the towers and mounts been sold yet? What about the alt brackets?
Eric
56 Chevy custom cab step side under construction
55 Chevy 210
68 SWB Stepside back burner under construction
72 Chevy LWB
84 CJ 7
05 Chevy 1500 Crew Cab
30X40 DOGHOUSE(shop) with many add ons
Chevy_Man is offline   Reply With Quote
Old 09-10-2009, 09:06 AM   #21
Hart_Rod
Hart_Rod's Avatar
Eric
I still have them both.....
Old 09-11-2009, 08:14 AM   #22
Hart_Rod
Hart_Rod's Avatar
Bed, tailgate and heat shield have been sold...everything else is still available.
Old 09-11-2009, 05:20 PM   #23
Number98
Prestige Worldwide
Number98's Avatar
Rob,
You entertaining offers on that engine and tranny??
J
Number98 is offline   Reply With Quote
Old 09-11-2009, 05:29 PM   #24
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I will take the fan shroud sending PM.
Old 09-11-2009, 05:42 PM   #25
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Number98 View Post
Rob,
J
What ya thinking J?
Shroud sold! Thanks
R/
