Old 09-08-2009, 11:54 AM   #1
neto
Brake line size
I need some information. I searched for brake line sizes such as 1/4, 3/16. I found a threads but none where specific. I have already converted to 5 lug disc brakes up front and drum in the back. I'm using the poly vinyl armour brake lines (green).
1. What size to I go to the back brakes? The lines are 3/16 at the axle.
2. What size to the front from the MC to the PV?
3. What size from the PV to the disc?
Thank you
Ernest
neto is offline   Reply With Quote
Old 09-09-2009, 03:35 AM   #2
neto
Re: Brake line size
Anyone?
Old 09-09-2009, 08:09 AM   #3
62 short step
62 short step's Avatar
Re: Brake line size
Thank you
Ernest
This is from what i've seen.
1. 1/4 to back brakes then splits to 3/16 to each wheel.
2. 3/16
3. 3/16
When i did mine i just ran all 1/4.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 09-09-2009, 08:32 AM   #4
rookierodbuilder
rookierodbuilder's Avatar
Re: Brake line size
would there be anything wrong with running all 3/16?
rookierodbuilder is offline   Reply With Quote
Old 09-09-2009, 05:45 PM   #5
protrash64
Resistance is Futile
protrash64's Avatar
Re: Brake line size
No, both my trucks have 3/16's all the way.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 09-09-2009, 11:18 PM   #6
TR65
TR65's Avatar
Re: Brake line size
Just to vote.
I ran 1/4" everywhere except across the rear axle. The big front discs require more fluid to be moved than the old drums.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 09-10-2009, 12:01 AM   #7
bubba327
HOW long until spring??
bubba327's Avatar
Re: Brake line size
I researched this a while back and found a thread where Baer and Wildwood both recommended 3/16 for all applications both disc and drum.
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 09-10-2009, 08:45 AM   #8
neto
Re: Brake line size
Thank you all very much. This is great information.
Old 09-10-2009, 12:11 PM   #9
rookierodbuilder
Re: Brake line size
I appreciate the advice as well and thanks neto for starting the thread.
Old 10-27-2013, 10:16 AM   #10
elf w/capital T
Re: Brake line size
Good info thanks!!
elf w/capital T is offline   Reply With Quote
