Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-08-2009, 02:34 PM   #1
Ont67shortbox
drag radial tire pressure
I made it out last weekend for some T&T,but my tires are just too hard to hook,just spun off the line (2.06 60foots).I am going to try a friends Hoosier 31x10.5x15 drag radials,what would be a good starting pressure? Thanks
Ont67shortbox is offline   Reply With Quote
Old 09-08-2009, 03:32 PM   #2
limitedstreetoutlaw
limitedstreetoutlaw's Avatar
Re: drag radial tire pressure
I ran 15psi in my MT drag radials hooked real good
_____________________________
1968 c-10 stepside "THE GRAPE APE"
all motor
1.56...60ft
7.41...1/8
89.41..1/8
limitedstreetoutlaw is offline   Reply With Quote
Old 09-08-2009, 11:56 PM   #3
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
I was told by the outlaw guys that if you have to run much lower that 15-17 psi you need to do some suspension tuning.
68 C-10 KID is offline   Reply With Quote
Old 09-09-2009, 09:47 AM   #4
swb85
On a budget like Fred Sanford
swb85's Avatar
At the track you want to run the pressure as high as you can while maintaining traction. Usually radials like a little bit higher pressure than bias-ply's do. I've never used hoosier DR's, but with mickey's I usually start around 22psi and start working your way down from there. Remember track prep and suspension setup are much bigger factors to traction when running radials.....they're not near as forgiving as bias-ply's.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 09-10-2009, 04:46 AM   #5
hotrod 80
mini truck racer
hotrod 80's Avatar
15-18 at the lowest . A little change makes a big difference . You need a good low pressure gauge and take notes on your time slips or log book to study later .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 09-11-2009, 06:48 PM   #6
Ont67shortbox
Thanks guys, I will start at 20lbs and adjust from there,
Old 09-12-2009, 12:00 AM   #7
Rodms
Rodms's Avatar
20 may be too much depending on weight!!!!!
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 09-12-2009, 12:26 AM   #8
Super73
Super73's Avatar
20psi worked awesome today with a little street test on my favorite back road 60' stretch.. No burn out and 75% throttle rolling in to it very quickly. Helps I have the front end loose as a goose right now, squat dialed in to the rear suspension and most likely a 50-50 weight bias..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-12-2009, 07:24 PM   #9
Wild83C10
Wild83C10's Avatar
Super, what size radials are you running?
Did you ever get the fiberglass nose on?
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 09-12-2009, 08:36 PM   #10
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
shhhhh go old school......get some white shoe polish ( the one with the sponge on the top) wipe it across the outside edge ( on the tread) then let it rip... the polish will be worn off where it touchs.....drop 1 lb for every 1/4" still on the tire or add 1 lb if it's completly worn off till you find the sweet presure..DON"T WORRY if the let and right sides are a pound or 2 diff its because of the weight being tossed maybe a bit more on one side
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 09-12-2009, 11:35 PM   #11
Super73
Super73's Avatar
Wild,
I have a 315/60/15 MT ET Street Radial on it with a 12" wheel.
I actually have the sheetmetal fenders on it right now with no hood and took the plasma to the inner fenderwells. The glass should save another 30-50lbs over the way it sits right now.
Old 09-13-2009, 08:11 AM   #12
Hottrucks
Hottrucks's Avatar
I k ow it sounds dumb but air up ypur fronts for al there worth to cut down on rolling resstance
and let her eat!!
Old 09-14-2009, 11:42 AM   #13
Ont67shortbox
update....last week I went out,engine is 3 weeks old,had a 2.06 60foot and best of 13.85@99,this week I ran the hoosier drag radials with no other changes,left everything else the same best was a 1.72 60foot with a 12.72 @105,I couldn't believe the difference,now it is time to start tweaking and tuning,Thanks for everyones help,I hope next report will be low 12s,high 11s Brian
Old 09-14-2009, 09:46 PM   #14
Wild83C10
Wild83C10's Avatar
Nice. At least you are moving in the right direction. Once the motor loosens up you will be hitting your ET goals.
Where the hoosiers you first DR tire?
turbo=
Old 09-14-2009, 10:33 PM   #15
Ont67shortbox
Yes ,I just used the DRs because a friend had them and said try them out.I stayed at 19 lbs all day just because it was fairly consistent,but can still play with tire pressure and jetting etc.I am sure with some tweaking a 1.6x 60 is possible,not bad for an all steel 67 short box,I do need to find some scales somewhere and weigh it. Alot of suspension tuning to try over the winter,but I am really pleased so far.
Old 09-14-2009, 11:35 PM   #16
Super73
Super73's Avatar
Congrats on the new best...
Old 09-15-2009, 10:21 AM   #17
Ont67shortbox
Thanks Super, alot of the guys on here were inspiring and helpful when I was building the truck.Its a great site full of info.
