Old 09-08-2009, 02:53 PM   #1
hoss67
hoss67's Avatar
Dash instrument question
I have a 3 lense instrument panel. I am wanting to go to a deluxe gauge one. I know that the plug in panel is different. I have an aftermarket temp. and oil gauge that I am wanting to eliminate. Would it be hard to change out my old instrument panel and get a deluxe one? If not, what all would I have to do. I tried looking this up but could not find it anywhere. Thanks
hoss67 is offline   Reply With Quote
Old 09-08-2009, 03:16 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Dash instrument question
Haven't done the swap myself, but this might help:http://www.gmcpauls.com/Tech%20Tips1.htm
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 09-08-2009, 04:28 PM   #3
69GMCLonghorn
69GMCLonghorn's Avatar
I don't think it's that difficult. You just need to have the funds to buy the pieces. A new instrument cluster full of gauges can run $700. If you buy it piecemeal, I'm sure it's cheaper. Plus, you have to buy (or do your own) wiring harnesses.
69GMCLonghorn is offline   Reply With Quote
Old 09-08-2009, 04:38 PM   #4
hoss67
hoss67's Avatar
Would I have to change the whole wiring harness or can I just change the end that plugs in back of deluxe gauge cluster?
Old 09-08-2009, 04:41 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
In the link I posted it shows what wires need to be moved around in the dash cluster socket. As far as I know you can use the harness you already have.
Beat it to fit,
Old 09-08-2009, 04:43 PM   #6
hoss67
hoss67's Avatar
Thanks Sinister I printed it out. I think I can do it. I just wanted to be sure I didn't need to get the correct end that goes in back of the deluxe gauge panel.
Old 09-08-2009, 05:40 PM   #7
cparman
sharp as a marble
I did the GMC PAUL'S conversion, and it went smooth as butter !!
cparman is offline   Reply With Quote
