09-08-2009, 02:58 PM | #1 |
Wanting to make LWB 1970 to SWB!!
I have a 1970 c10 2wd with the long wheel base, where or what is the degree of difficulty of shortening the frame to make it the much more desired short wheel base?
09-08-2009, 04:09 PM | #2 |
Re: Wanting to make LWB 1970 to SWB!!
This is a good place to start: http://67-72chevytrucks.com/vboard/s...d.php?t=123624
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
09-08-2009, 04:11 PM | #3 |
^^ Just beat me to the punch..... This was the method I used.
09-08-2009, 07:40 PM | #4 |
VA72C10
Welcome to the board. Before you cut it up....consider what you're going to use the truck for....plus, there are many that are leery of cut frames if you ever go to sell the truck so don't necessarily expect SWB money. Also consider that a LWB will ride better. Finally, the recent trend I have noticed is that longbeds are becoming more popular...I'm sure it's a combination of the fact they can be had cheaper, they are different, and they just look so darn good when they are dropped...
Whatever you decide to do, welcome to the board....you've found an excellent place to learn.
Looking for a 67-72 swb or blazer project in or around VA. |
09-08-2009, 07:41 PM | #5 |
VA72C10
Oh, and we need pictures of your truck
09-08-2009, 11:07 PM | #6 |
I like the lwb but to each his own but i will post a pic of my lwb 70 one bags
09-09-2009, 08:32 AM | #7 |
Happy to be here
The solution there is to do it correctly, and document the process. If you have clear pictures showing quality work, most "truck guys" know this doesn't diminish the value.
09-09-2009, 10:17 AM | #8 |
Cutting the frame is only half the battle. You can also cut the bed itself down. That takes a little more time/effort.
09-09-2009, 10:35 AM | #9 |
The cut frame I've done bring the same money as oe shorts, at least all of them so far they have.
09-09-2009, 02:21 PM | #10 |
wow thats a nice one
70 SWB STEPSIDE 70 BLAZER 09 challenger |
09-09-2009, 10:03 PM | #11 |
Here's the easy way to shorten a frame
http://www.67-72chevytrucks.com/vboa...d.php?t=361929 Unfortunately for you the distance on this one is the killer.
