Old 09-08-2009, 09:50 PM   #1
NYC-10
screamin eagle
NYC-10's Avatar
getting the right starter
I have a 1970 k10 4x4 with a 350 and an automatic transmission-I cannot find the right starter to fit this combo.can anyone help?
SCREAMIN EAGLE
NYC-10 is offline   Reply With Quote
Old 09-08-2009, 09:58 PM   #2
stellar
Re: getting the right starter
what has been changed from stock? You may have to change the flywheel.
stellar is offline   Reply With Quote
Old 09-08-2009, 10:04 PM   #3
NYC-10
screamin eagle
NYC-10's Avatar
it's all stock-The last starter I got it seems the nose is not long enough so the starter gear doesn't fully contact the flywheel,but the parts book says it's the right starter.
SCREAMIN EAGLE
Old 09-08-2009, 10:07 PM   #4
stellar
Do you have the original starter? If so have it rebuilt. Is the original starter a cast iron housing?
Old 09-08-2009, 10:10 PM   #5
NYC-10
screamin eagle
NYC-10's Avatar
I traded in my core which was a big mistake
SCREAMIN EAGLE
Old 09-08-2009, 10:15 PM   #6
stellar
tomorrow I will check my books and see if I can tell you what should be in there.
Old 09-09-2009, 12:27 AM   #7
Jurassic-1
Jurassic-1's Avatar
Was the starter bolted on with a straight across bolt pattern or diagnal bolt pattern? if you have the smaller flywheel it would be the same as a powerglide and would take the straight bolt pattern.
Jurassic-1 is offline   Reply With Quote
Old 09-09-2009, 08:40 AM   #8
NYC-10
screamin eagle
NYC-10's Avatar
I will check on the bolt pattern
SCREAMIN EAGLE
Old 09-09-2009, 08:46 AM   #9
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Smile Re: getting the right starter
Bosch # SR528X Delco #'s 1108345, 1108350, 1108355. Hope this will help!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 09-09-2009, 11:33 AM   #10
NYC-10
screamin eagle
NYC-10's Avatar
It seems like a starter from a 400 block fits-does this make any sense?
SCREAMIN EAGLE
Old 09-09-2009, 11:51 AM   #11
71tahoe
71tahoe's Avatar
I'm not sure about parts stores any more. I went to Advance Auto Monday for a set of front brake shoes for a 70 GMC and the computer listed a number for PADS!
I thought the only difference was the nose cone on the starters. Auto vs manual and 153 tooth vs 168 for the autos. I6 or any V8 could use the same starter as long as the flywheel teeth were the same.
71tahoe is offline   Reply With Quote
Old 09-09-2009, 12:07 PM   #12
lks dcvn
lks dcvn's Avatar
Why not pick up a hi-torque mini-starter from Skip White on Ebay - I got mine shipped for under $100 (from memory)?
lks dcvn is offline   Reply With Quote
Old 09-09-2009, 02:33 PM   #13
stellar
please give specifics of transmission. This will determine what starter to use.
Old 09-09-2009, 04:57 PM   #14
NYC-10
screamin eagle
NYC-10's Avatar
turbo 350
SCREAMIN EAGLE
Old 09-10-2009, 11:30 AM   #15
stellar
I'm not sure, but I am guessing it is a hydromatic. Is that correct? If so ask for a lester number 3510 starter. That is a starter with an aluminimum housing with staggered mounting holes, using 2 long bolts, and not the straight across with 1 long and 1 short bolt.
