Old 09-08-2009, 10:14 PM   #1
AJLChase
AJLChase's Avatar
Spark plug wires under Ram horns?
Tips? Seems their are two wires on each side that are running in between the motor mounts...I was trying to tug on them to see if I could slip them through the bracket but was worried I'd do major damage and not be able to slip the new ones in there.
AJLChase is offline   Reply With Quote
Old 09-08-2009, 10:17 PM   #2
faribran
Re: Spark plug wires under Ram horns?
i pulled mine thru using the end that plugs into the distr.(its a bit smaller...also put some lube on it)
thatz a nice look.. the wires are tucked away.
faribran is offline   Reply With Quote
