Old 09-08-2009, 10:17 PM   #1
redbaron69
redbaron69's Avatar
disk swap
getting ready to put 71-72 spindles on my 69. are there any differance in the ball joints? i know the tie rod ends are different. can you think of any other 71-72 parts i will need. thanks guys
69 short fleet 350/350 "under construction"
70 short step 307/3 speed
redbaron69 is offline   Reply With Quote
Old 09-08-2009, 10:24 PM   #2
AusTx68
AusTx68's Avatar
Re: disk swap
Yes the ball joints are different. They look similar but the taper is different. Do you already have the brake booster and prop valve?
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 09-08-2009, 10:30 PM   #3
redbaron69
redbaron69's Avatar
Re: disk swap
no booster or valve yet, this is a frame off build and doing the frame and suspension now. thanks for the response you probally saved me trip back to napa
Old 09-08-2009, 10:30 PM   #4
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
Re: disk swap
If you are gonna change the inner and outer tie rods you'll need the center steering link also. I'm currently in the process of saving up and getting the parts to do the same with my '69. I think there is a tie rod adjuster you can get that has the different threads for 71-72 outer's and your stock inners.
stealthy '69 is offline   Reply With Quote
