Old 09-08-2009, 10:27 PM   #1
rico7769
Hybrid67
rico7769's Avatar
Frame Identification ?!?
I have yet to come across something on our truck that hasn't surprised me. So today, as my brother and I were changing the tranny filter and fluid out, I noticed a date stamped on the driver's side under the door of the frame. Says 10-6-86. Is that the date of manf. for the frame? I know our cab is 67, the bed is fleetside from 68 or later due to side marker lights and the motor is from a 77 (sb350) and the tranny stamp appears to identify as an 88. What a mess. Luckily, it all is working fine and seems to be running good. Bought around a year ago and still getting little "presents" all the time. Any info on the frame? There is also a 5-6 digit number code above the date on the frame.
Keep em' Running!
All show.....no go
rico7769 is offline   Reply With Quote
Old 09-10-2009, 08:39 AM   #2
KEL
72 GMC
KEL's Avatar
Re: Frame Identification ?!?
ttt
KEL is offline   Reply With Quote
Old 09-10-2009, 10:22 AM   #3
redbaron69
redbaron69's Avatar
i have seen 2 locations on the drivers side between the cab mounts and on the drivers side just behind the steering box. (on top of the frame rail) i have never seen a date stamped like you mentioned, its always been first number is year and the rest should be last digits of the vin. guys if im wrong please correct me.
69 short fleet 350/350 "under construction"
70 short step 307/3 speed
redbaron69 is offline   Reply With Quote
Old 09-10-2009, 02:51 PM   #4
sameyrasmea72
sameyrasmea72's Avatar
If you look good, those #'s or a similar # are on all frames. I think it is the part # for the frame. The 10--6--?? is not a date code or my frame would be from 1918.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 09-10-2009, 10:00 PM   #5
pritch
pritch's Avatar
This is where they are, on the drivers side. There are others on the pass side. I've never seen 2 the same.
However, if you look close you can see that "420" is part of the number, and it shows up again in other places:
Just sayin'
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 09-11-2009, 07:11 PM   #6
rico7769
Hybrid67
rico7769's Avatar
thanks everyone. Its good to have people like the members to reach out to with questions like this. You all have proven to be a valuable resource throughout our project. THanks!!!
Keep em' Running!
All show.....no go
