Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 09-08-2009, 11:53 PM   #1
JimmyFloyd
Tach Cluster with wood grain from a 72
I got a Tach Cluster out of a 72 BB truck. Wood grain on it has some issues. Also have the matching glove box door in much better shape. Appears to be original.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 09-09-2009, 10:28 PM   #2
byrd
Union Electrician
byrd's Avatar
Re: Tach Cluster with wood grain from a 72
If the tach works it is worth $250, or more. The printed circuit is very nice and makes the dash a little more valuable... Just my .02
Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 09-10-2009, 08:38 AM   #3
JimmyFloyd
That's good news. Is there a way to test the tach outside of the truck? Or do I need to get mine running before I can test it?
I'm still on the fence on whether I want to keep it or not. Would be nice to have a Tach in my Blazer, but it would also be nice to the money to help get it on the road.
Old 09-28-2009, 07:49 AM   #4
byrd
Union Electrician
byrd's Avatar
It is possible to do outside of truck, but you need access to a coil off a points truck or another HEi to get the signal from. Just put 12 volts on the positive, and hook the metal tin to ground(make sure that has a good ground!), and hook the signal up from the dizzy and it will then move or not.
Zip:40272
