View Poll Results: What Chassis Paint would/did you use? | |||
POR-15 | 5 | 26.32% | |
Eastwood Extreme Chassis Black | 4 | 21.05% | |
Summit Chassis Paint | 0 | 0% | |
Other | 10 | 52.63% | |
Voters: 19. You may not vote on this poll |
09-09-2009, 12:49 AM | #1 |
Chassis Paint
Hey Guys, I'm trying to figure out which paint I should use on my frame, suspension, and rear end. I'm looking at POR-15, the Eastwood Extreme Chassis black, or Summit has a chassis paint. Anyone have any strong opinions on the above?
09-09-2009, 12:59 AM | #2 |
Re: Chassis Paint
Most automotive lines have a "chassis black" or "rally black" that are single stage urethanes, extremely durable, and give a semi gloss finish. You can get custom colors mixed in an appropriate single stage too.
Have your frame sandblasted, prime with an epoxy primer, and paint. I have not used POR, but understand it is great on a rusty piece, so that is an option if you can't chemically(dip) or mechanically(media blast) strip the chassis first. I just did mine with Sikkens Epoxy Primer and Rallye Black. Looks great!
292 + TKO500 |
09-09-2009, 01:11 AM | #3 |
Senior Enthusiast
Re: Chassis Paint
You might want to review the following link for additional opinions:
http://67-72chevytrucks.com/vboard/s...&highlight=por I used POR-15 on my current truck and wouldn't use it again. It was prepped as suggested back when, but it hasn't held up that well showing quite a few rust pits here and there. My previous ride was a 46 Ford sedan. I coated the chassis with the rust converter that Eastwood now sells, followed by hardened acrylic enamel and it looked like new after 8 years and 300,000 miles. If I were doing my truck over today I would probably do the chassis with Zero Rust (assuming it's for a driver vehicle). |
09-09-2009, 02:33 AM | #4 | |
Re: Chassis Paint
It dosent hold up well to scratches even when prepped as recomended. Dont be a cheapo get it powder coated. |
09-09-2009, 03:19 AM | #5 |
Re: Chassis Paint
I am going the spraybomb route, as I am not doing a frame off, yet, I just want a clean driver, used the rustoleum black rust converting primer, and their satin black wheel paint. Down the road after I finish my 68 firebird resto, and my 66 tempest resto, then I will do the 63 C10 and go the powder coat route.
09-09-2009, 08:12 AM | #6 |
Re: Chassis Paint
Powder coat on a show truck. Epoxy primer on a nice driver.
Chop |
09-09-2009, 08:26 AM | #7 |
Re: Chassis Paint
We used KBS on the chassis of my 66. It is similar to por 15 and I was told KBS was formed by the lead chemist and marketing guy for Por and it is suposed to be better. We also used it to do the back side of all the body panels and bottom of the cab. http://67-72chevytrucks.com/vboard/s...=346598&page=2
09-10-2009, 11:23 AM | #8 |
Airport Bum
Re: Chassis Paint
I use single stage black.....
Looks as good as powder, but can be touched up/modified.
1964 Chevrolet C-10 1941 Chevrolet coupe 1962 Thunderbird 1959 Edsel Villager 1963 Skylark |
