Old 09-09-2009, 01:23 AM   #1
oldiron
Designated Grumpy Old Man
oldiron's Avatar
71 c10 4x4 rear end
I ran a search but did not come up with anything. What years will interchange with a 71 c10 4x4 rearend 3.73 gears?
oldiron is offline   Reply With Quote
Old 09-09-2009, 01:43 AM   #2
2tons of fun
Re: 71 c10 4x4 rear end
any if you have a welder and a grinder.
2tons of fun is offline   Reply With Quote
Old 09-09-2009, 07:26 AM   #3
I`ve never been sure if the rears got wider in`70 like the 2wds did.The complete assembly will swap from earlier.The only difference after`72 is the mounting of shocks and springs,which cam be moved.It`s bolt-in from`72-back.
Old 09-09-2009, 09:03 PM   #4
oldiron
oldiron's Avatar
And talent and I aint got none.
I understand the shock mounts. I'm concerned about spring perch width & if the pinion is further forward from the center of the center of the axles.
Thanks for the info.
