09-09-2009, 11:05 AM | #1 |
disk brakes for 1970 Blazer
Is there anyone out there that sells a kit for disk brake conversion for 4 wd, 1970 blazer?
09-09-2009, 11:21 AM | #2 |
SKINNY TIRES RULE!
Re: disk brakes for 1970 Blazer
Front disks should be a direct swap with a 71-72 setup. If you become a subscribing member, you could post a "wanted to buy" thread and I'm sure someone would have everything you need.
There are several rear disk kits available too - check out http://www.blackbirdscustomtrucks.com/
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
09-09-2009, 06:36 PM | #3 |
if you just want the disk brake set and you're not talking about the brake booster or master cylindar then you should just go to a salvage yard and find a half ton axle that you can get the parts from. I just did the swap for around $100
09-09-2009, 08:43 PM | #4 |
that is kind of what we figured out today (my mechanic), we started the search after a conversation with the guy from Blackbirds custom trucks, he was a wealth of knowledge.
