09-09-2009, 12:44 PM | #1 |
73 spindles on a 66
will 73 -87 spindles fit right on a 66 and will it keep the same height?
09-09-2009, 01:17 PM | #2 |
Re: 73 spindles on a 66
Using 73-87 BJ's they'll fit your 66 a-arms. You'll need adapter tie-rod sleeves as the tie-rod size differs between drum & disc set-ups. The 'height' will be the same unless you switch to dropped spindles .
09-09-2009, 02:04 PM | #3 |
X2.
Those parts and it's an easy swap. |
09-09-2009, 03:59 PM | #4 |
Questionable
And if you want some, I've got a good set of 73-87 uppers and lowers (off a '77 p/u?), along with a set of '68 uppers and lowers. Free for you, if you come pick em up. Pics can be provided if needed.
I'm about 5 blocks southeast of the Zoo in metro Atlanta.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 09-09-2009 at 03:59 PM. |
09-09-2009, 05:22 PM | #5 |
Cool. Does the master cylinder and brake booster bolt right up aswell?
09-09-2009, 06:41 PM | #6 |
That takes a little more effort. The easiest way is to grab an adapter from Captainfab here on the board & then bolt up the master cyl/booster. The 67-72 stuff works well but there are other options depending on the 'look' you wish to achieve.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-09-2009 at 06:43 PM. |
