Old 09-09-2009, 06:17 PM   #1
djw32
Washer and bolt for the fender
Where can I find the part number for the bolt and washer, the washer is about 1" in diameter, and the bolt has a point at the start and then works into the threads, that is the last one on the fender that goes through the frame( imagine that you're looking at the truck from the front)? I am missing the one bolt and washer on the passenger side.
David
I can post a picture on friday if need be.
djw32 is offline   Reply With Quote
Old 09-09-2009, 10:49 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Washer and bolt for the fender
why not go to the junk yard?
I doubt you'll ever find one at the dealer.
Old 09-09-2009, 10:57 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Become a subscribing member, post a WTB (want to buy) ad and I'll bet someone would be willing to send you a couple for the cost of postage.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 09-09-2009, 11:33 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
If this is what you need the washer is closer to 2". It goes in the larger square hole in the rear of the inner fender panel.
After reading your post a couple more times I'm thinking that's not the one you need....
LockDoc
Leon
Old 09-10-2009, 12:20 AM   #5
djw32
Lock Doc,
That is the bolt and washer I need.
2"...1"...washer...I was going off of memory.
Old 09-10-2009, 12:22 AM   #6
djw32
Southern California does not have junk yards full of 67-72 chevy truck. I was hoping that this bolt and washer would also be used on the 73-87 c-10.
Old 09-10-2009, 12:24 AM   #7
leddzepp
Moderator
leddzepp's Avatar
Where are you at in So Cali? I might be able to point you in the right direction...
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-10-2009, 12:39 AM   #8
djw32
I live in Brea
Old 09-10-2009, 12:43 AM   #9
leddzepp
Moderator
leddzepp's Avatar
www.kingstrucks.com
Jeremiah is also a board member. He is located in Escondildo, and has lots of OEM 67-72 truck parts. I have purchased stuff from him in the past, and he is good people. His contact info is on his website.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-10-2009, 12:50 AM   #10
djw32
Originally Posted by leddzepp View Post
www.kingstrucks.com
Thank you, Sir.
