Registered Loser
Turn signal ?s
My 63 GMC has factory turn signals but they don't cancel when I turn. Are they suppose to? If not, is there some way to make them self-cancel?
This truck is really showing me just how little I know about old vehicles. ![]()
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
and a few others
Re: Turn signal ?s
Yes, they're supposed to cancel. Could be a couple things, but you may need a new switch behind the steering wheel.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Rollin' Old Skool
Re: Turn signal ?s
i've got the same issue with my '66...however, left turn will cancel & right turn won't
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Turn signal ?s
I'm not sure if they are still available, but you used to be able to buy the plastic 'C' shaped part of the turn signal switch that the handle attaches to. This is what has the cancellation mechanism on it. They just get fatigued and brittle and break off. You might check with some of the aftermarket suppliers.....I haven't bought one in several years.
and a few others
Re: Turn signal ?s
It's part number 36-0603 at LMC but I wouldn't buy one until you take the wheel off and verify that's your problem.
Registered Loser
Re: Turn signal ?s
Thanks guys! I'm supposed to get my air cleaner back from powder coating today so I will probably head out to my buddy's house and do some tinkering on the truck. How does the horn button come off? From the diagrams I've seen it looks like it is held in by friction to a rubber ring.
60-66 Nut
Re: Turn signal ?s
The horn button just pulls off. Then you will have to remove the steering wheel to get to the turn signal switch. You'll need a steering wheel puller for that.
Registered Loser
Re: Turn signal ?s
That's exactly what happened!
Registered Loser
Re: Turn signal ?s
I tried replacing the turnsignal cam today but when I tried to remove the old one it had wires from the switch harnes attached to it with rivets and some sort of contacts on them. The replacement part doesn't have any way to attach the wires. I don't think the wires will even come off of the original part. I got the cam listed for a 63, should I try one from a different year.
Re: Turn signal ?s
the one you got is for a chevy you need the GMC part with all the wires on it
