09-09-2009, 08:23 PM | #1 |
Disc brake swap...Help!
Hey everyone, I was hoping I could get some info. I recently bought a 70 c10 w/drum brakes and I have a 71 c10 w/disc brakes. What do I have to do to swap the disc brakes from the 71 to the 70? I was told nothing is the same. I find it hard to believe they wont swap. Any help is greatly appreciated.
Thanks Eric |
09-09-2009, 08:27 PM | #2 | |
Re: Disc brake swap...Help!
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-09-2009 at 08:29 PM. |
09-09-2009, 09:44 PM | #3 | |
09-09-2009, 10:01 PM | #4 |
One more thing. I guess I should have been more specific. Can I swap just the spindles or do I have to do the whole front end, control arms, tie rods, ect.
09-09-2009, 10:38 PM | #5 |
I assume you have a C10? If so, the tie rod ends, adjuster sleeves, center link, and ball joints are specific to 71-72. Attached is a Word file with some info I compiled. My 69 has 86 light duty spindles (smaller rotors and bearings) that I installed back in 1995 before I knew what I was doing! Although, they work very well, even towing a light trailer. I had my rear axles re-drilled back then for 5 on 5.
By the way, 69-70 C10 front end parts are the same.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
09-09-2009, 10:53 PM | #6 |
I really hate wet sanding!
You will need the mastercylinder and proportioning valve from the 71...the power booster on the 70 should work just fine.
09-28-2009, 05:47 PM | #7 |
also youll need to swap the front brake lines. thats where im at on mine now as well
1967custom |
09-28-2009, 05:54 PM | #8 |
easy way is to just unbolt the crossmembers and take the whole thing from one to the other//
09-28-2009, 06:02 PM | #9 |
Sorry to thread steal but is redrilling the back axleshafts the only of best way for going from 6 lug to 5. Wanting 5 lug disks all the way around, found lots of info redarding front swaps, but can't find much on rear 5 lug disk brakes, any info would be awesome.
1970 Chevy C10 Short Stepside 4.3L LT 1965 Shelby Cobra AC 427 Comp Car 1965 Sunbeam Tiger 305 1984 Dodge D150 5.9L Magnum 1995 Dodge 3500 V10 1991 Ford 250 460 |
09-28-2009, 06:21 PM | #10 | |
09-28-2009, 06:23 PM | #11 |
BTW... I just want to thank everyone for all the info.
09-29-2009, 01:28 AM | #12 | |
09-29-2009, 09:45 AM | #13 |
406 Powered
I just finished swapping my 70 chevy to five lug. I found a doner 71 front end and used the spindles and went to the auto parts for new pads and some other parts. I also swapped the outer tie rods off the 71. Also used a 72 set of axles and slid them right in my rear diff. Easy swap...There is a forum that names all the parts i think.....
70 GMC 68 c10 2002 silverado 72 4x4 |
09-29-2009, 12:34 PM | #14 |
Project Junkie! Fishing Poor!!
The 71-72 Ball joints, and tie rod ends are different than 63-70. There are a couple of ways to do the swap.
You can use your existing engine crossmember and swap out the upper "A" arms, lower "A" arms, tie rods, drag link, and other steering components except the pitman arm. You can keep your "A" arms and swap out all of the above and change the ball joints. You can swap out the whole crosmember and all steering components. (This is the way that I do it) Above adresses the steering only. Now for the brakes.. If keeping your crossmember, there are a couple of things that you can do. The cheapest and easiest way is to just put an adjustible proportioning valve in between your existing proportioning valve and the rear brakes. You can use the donor trucks mastercylinder, booster, brake rod, and proportioning valve. Custom bend the vertical brake lines if you are using your front crossmember. If using the donor trucks complete front crossmember with everything atached you can do the following. You can use the donor trucks mastercylinder, booster, brake rod, and proportioning valve, if the brake lines are in good shape use all of them including the vertical ones. If not, bend your own or purchase pre-bent ones. If using your mastercylender/ booster assembly. Custom bend the vertical brake lines and put an adjustible proportioning valve in between your existing proportioning valve and the rear brakes. There may be a few steps left out but this gives you what you need to use and or buy. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
