carb help
i have a 86 chevy k10 silverado with a 305 got 2 questions . first question is the engine has an eldobrock performer intake on it and the po had a holley 850 double pumper on it i have taken that off and cleaned the intake up and i have an eldobrock 600 cfm performer carb on it do i need the adapter plate that the po had on the intake or should i use the thin metal plate that came with carb? 2nd question how do u hook up the tv cable from a th700r4 trans to the carb?
Badass
Re: carb help
the 800cfm was to much for that motor right?
and yes you need a tv cable on the 700r4 i cant realy help u with the rest
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
Re: carb help
Edelbrock sells a bracket. Here is a link to the page. http://www.edelbrock.com/automotive_...throttle.shtml
By reading Edelbrock's website, I don't think you need an adaptor. You can set the carb on the intake and open the throttle. If the throttle blades clear the manifold you should be ok.
I can still count my vehicles on two... wait three hands. |
Re: carb help
I'm assuming the Performer carb. is a square bore, is the intake for a square bore or spread bore carb?
I'm thinking if the PO used the adapter with the Holley, which was most likely a square bore, then the intake must be for a spread bore and then yes, you would need to use the adapter.
Keith ------------- 1980 C-10 1981 C-30 |
1962 C-10
Re: carb help
You will not need an adapter on your Performer intake.
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
Re: carb help
ok the intake is a dual bolt patteren but its a spread bore and the carb is a square flange one place says to use the thin plate that came with it and the other says i dont need anything whos right?
