Moving engine back
So I'm moving my V8 in my '67 from the front mounts to the rear I6 mounts for better weight distribution and better access for working on the ancillaries.
Do I need to swap the mount towers from left to right and right to left? It seems to line up better that way. Will I need to drill a hole in the cross member for the lower bolt? There doesn't seem to be one in the right spot. Thanks! |
Re: Moving engine back
i moved mine back but used different towers, and still had to drill a hole in the crossmember for the stud/bolt.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
![]() Join Date: Jul 2004
I think you want to find a set of 6 cylinder frame mounts for a 250 engine for a true bolt in deal as they just don't move back, they are different. 292 mounts are is not what you want either, one is offset on the 292.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
What Green Machine said, get the proper towers and you won't have to drill any holes. You need non 292 inline 6 towers. There are lots of them come up for sale on the parts board with pretty good regularity.
Cool. Thanks!
![]() Join Date: Mar 2003
The big block mounts will move it back 1''
![]() Join Date: Apr 2005
Not to hijack your thread, but I'm doing the opposite of you and have a question. I've got the straight 6 motor mounts and want to move the motor forward. I have tall valve covers and the are almost touching the firewall. I already have a set of the V8 motor mounts and am wondering how far forward they will move the engine?
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 09-10-2009 at 11:23 AM. |
About 3 inches, maybe 4.
