Body bolt restoration?
What are guys doing to restore body panel bolting when you don't paint an assembled truck? Is anyone buy new bolting?
1967 SWB C-10, BBC 454, T400, 3.73 posi, 20" Coys 1972 K5 Blazer, SBC 400, 4 spd, 3.73, 6" lift, 35" mud grapplers 2011 Sierra Denali HD, 6.6 L Duramax, RBP 96R rims, leveled and Nitto trail grapplers, ![]() 2009 Acura MDX |
Body panel bolting restoration?
What are guys doing to restore body panel bolting when you don't paint an assembled truck? Is anyone buy new bolting that doesn't require painting?
Re: Body bolt restoration?
you can buy new or look at Eastwood at there tumblers and coatings and refurbish what you have. Or bench grinder w/wire wheel (and proper safety equipment) and get to cleaning and painting/coating.
![]() Join Date: May 2007
Re: Body panel bolting restoration?
Check with AMK Products.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
whenever whereever possible i prefer new stainless fasteners
X2
And the stainless bolts also polish up nice with a buffer.
1977 Camaro 468 BBC - SOLD - 1972 Chevy SWB....in the works!! ![]() 2006 Crew Cab Dmax/Allison Summit White-SOLD- 2009 Toyota Tacoma V6 Pre Runner - daily driver - my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595 |
somebody should read the board rules about doubleposting
#9 | |
The Older Generation
![]() LockDoc
![]() Join Date: Oct 2007
Can you put the rusted bolts into something like CLR cleaner and remove the rust?
Sounds like a good idea! Throw one in there and report back, I'd be interested to know. I don't have any CLR, so I can't do it.
#12 | |
Also, some guys delute it with water....50/50 mix.....takes a little longer but isn't as dangerous to handle either....either way, be careful!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 09-10-2009 at 06:46 PM. |
#13 | ||
You are correct sir........
2 posts with-in 2 minutes of each other is not cool at all......and coincidentially....against the rules. Copied and pasted from the rules: Quote:
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() Last edited by LONGHAIR; 09-10-2009 at 08:05 PM. |
#14 |
My bad, missed that one...apologize for the disruption
#15 |
I would buy new bolts/nuts, not necessarily stainless but just new. I've purchased the black phosphate coated ones before and they look good. Cheaper and easier in the long run.
#16 |
Are these bolts just a standard fine thread bolt and any fine thread bolt could be used (minus the pointy end)?
#17 |
If you want cheap then go to Tractor Supply, they have them in bulk. Doors hinge bolts are fine thread but I think the others are course.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#18 |
![]() Join Date: Mar 2003
When I restored my truck ,I bought new ones for the front fenders and used the origional for most,but most of mine weren't rusted and used stainless steel for the fuel lines and the wiring along the frame rails.
#19 |
I am thinking I might try that Caswell black oxide kit, looks simple enough to do and for the right price. I am painying my truck a 1972 steel cities grey metallic so should the blackened bolts should go good and not stand out to much.
1967 SWB C-10, BBC 454, T400, 3.73 posi, 20" Coys 1972 K5 Blazer, SBC 400, 4 spd, 3.73, 6" lift, 35" mud grapplers 2011 Sierra Denali HD, 6.6 L Duramax, RBP 96R rims, leveled and Nitto trail grapplers, ![]() 2009 Acura MDX Last edited by hemihead; 09-11-2009 at 11:49 PM. |
#20 |
as far as cleaning rusty bolts// just regular kitchen vineager does an excellent job without the worry of structural compromise that acid hasb it's also alot cheaper plus you can strain it and use as salad dressing for unexpected company
#21 | |
I leave the bolts in the solution a little longer and let them soak in the sealer for a while (hour, overnight) then strain them and let them dry. I have a spray bottle with some of the sealer in it and give them a little sparay after they are dry before installing. When they are done right they look real nice. |
#22 |
Moderator
Metal Ready from POR 15 works fantastic. It also leaves a zinc phosphate coating and etching that helps paint adhere and prevents further corrosion. Muriatic acid (pool acid) also works well for removing rust, just doesn't leave the coating.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#23 | |
http://en.wikipedia.org/wiki/Parkerize |
#24 | |
Moderator
#25 |
Well just placed my order for the oxide kit, the standard kit should leave a bit of a oil/shiney finish which should look good withthe paint color.
I have access to a bead blaster so I guess I have some work ahead of me while waiting for the kit.
