Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-10-2009, 12:40 AM   #1
iluvmy72
need more horses....any advice?
I have a 1997 Stock 7.4(454)vortec. The skinny: I want 450 HP. And I want to keep it when I'm towing a trailer up a grade while the A/C is blasting and the engine is still cool and not over heating. Is that asking too much? Money is tight so what would be the best route to go with headers/exhaust system and after market air cooler. I've been thinking about water injection and a different cam. But I'm not quite sure which cams would get me significant gains in a stock engine. Would that make a difference? Hell, I had a 454 in a luv back in the day that got 477 on the dyno. I know this engine can do better than 298. It's a 454 for gods sake. I mean when these newer vortec engines hit the market in 96, all GM could do is rave about the 7.4 model being the pinnacle of their truck engine. What about reprogramming the CPU or a Bully Dog setup?
iluvmy72 is offline   Reply With Quote
Old 09-10-2009, 10:04 AM   #2
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: need more horses....any advice?
Yes you're asking too much if this is the case.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 09-10-2009, 12:38 PM   #3
Super73
Super73's Avatar
There are trade offs every where. Do this, loose that ect.. Why don't you provide us with a budget. One mans money being tight is anothers fully built engine
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-10-2009, 04:26 PM   #4
fiddy9apache
fiddy9apache's Avatar
i would do exhaust, and send your pcm off to PCMforless.com
im guessing this is a tow rig? the vortec 454 are nothing more than a torque monster. gm hasnt built a "performance" big block since the musle car days if you ask me. it would take alot of money to get big numbers out of it.
fiddy9apache is offline   Reply With Quote
Old 09-13-2009, 12:32 AM   #5
iluvmy72
yeah....it's a tow rig
Old 09-13-2009, 02:11 PM   #6
Marv D
Registered Truck Offender
Marv D's Avatar
Plain and simple......It takes burning fuel to make power. Burning fuel creates heat... see the problem.
If I were going to build a tow motor,, and absence of a budget...... I'd be looking at STROKE!!! 511" stroker packages are getting pretty reasonable these days. Big inch, long stroke, I would not consider anyting less than a 305-325cc runner for this many inches, a hydraulic roller up around .57+" lift and short duration to keep low speed torque, and Holley MPFI Commander fuel injection,, probably wouldn't need anything more than the 30 lb / hr. injectors. 1000cfm throttle body... ought to be able to chassis tune it to decent fuel economy, and have the torque to shread most any drivetrain you put behind it.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 09-14-2009, 12:48 AM   #7
Super73
Super73's Avatar
Marv,
I'm not muchh of a big block guy, but a 305-325cc runner seems extreamly big. Are there heads on the market that utilize a smaller runner but flow decent numbers. I'm a firm believer in small ports that flow promoting TQ and power under the curve.
Old 09-14-2009, 02:03 PM   #8
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
i've seen some sewer sized 345cc's on a 540...and thats only a 540, i want a 632ci and i can then call it quits
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
