Old 09-10-2009, 01:04 AM   #1
cjthor
70 K20 Wheel backspacing Q?
Hey all,
So my K20 needs new shoes and am thinking about ditching my 16.5 rims for a set of 15x10 cragars. Id like to get a set of 35x12.50's and am wondering about backspacing. The truck does have a 3 inch body lift and I wanted to know what y'all think would be better...With a four inch backspaced wheel...will I need a spacer? Im doing searches as we speak but cant find an answer.... Don't me bro!!
cjthor is offline   Reply With Quote
Old 09-10-2009, 11:17 AM   #2
Burt4x4
Burt4x4's Avatar
Re: 70 K20 Wheel backspacing Q?
You should beable to get away with a 4"BS, but I would test fit before you buy.
Good choice in ditching the 16.5 wheels, unless they are beadlocked you can't run below 15psi without loosing a bead..anyway
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 09-10-2009, 06:14 PM   #3
skchevota
skchevota's Avatar
8 lug 15" ? if so, you will have to do some grinding on the calipers ...
skchevota is offline   Reply With Quote
Old 09-11-2009, 12:01 AM   #4
cjthor
Hmmm.I got drums.
Old 09-11-2009, 12:10 AM   #5
eric67m
eric67m's Avatar
What would the best size wheel be to run with 8 lug, 14 bolt large drum, disk in the front? Sounds like 15=modifications, 16.5= beadless tires= chance of roll off at low pressures.
Are any diameters better for tire selections (price and quality wise)?
Someday I will do my 8 lug swap and have wondered about what wheels to run.
Thanks in advance.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 09-12-2009, 03:36 AM   #6
cjthor
Originally Posted by eric67m View Post
what would the best size wheel be to run with 8 lug, 14 bolt large drum, disk in the front? Sounds like 15=modifications, 16.5= beadless tires= chance of roll off at low pressures.
+1
backspacing k20 wheels
