Old 09-10-2009, 02:54 AM   #1
Number21
Number21's Avatar
No reverse lights?
I recently bought a '79 1 ton with a 4 speed. The reverse lights do not work. If this was an auto, I'd guess there is a switch on the shifter or trans to turn them on. I have no idea with the manual. Where is the switch that turns them on?
Number21 is offline   Reply With Quote
Old 09-10-2009, 07:18 AM   #2
AirMale
AirMale's Avatar
Re: No reverse lights?
there should be 2 switches on your shifter base. neutral safety/reverse lights
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 09-10-2009, 07:50 AM   #3
Number21
Number21's Avatar
Alright...define shifter base. Under the boot in the cab?
PS - my neutral safety works just fine.
Old 09-10-2009, 08:16 AM   #4
AirMale
AirMale's Avatar
on my 86 there was relays on the shifter assembly under the boot
86 SWB 9.0 LITER
Old 09-10-2009, 03:09 PM   #5
hobsiscool
what about if it was 3 on the column, then converted to the floor...is there a switch in the steering column I can get to?
hobsiscool is offline   Reply With Quote
Old 09-16-2009, 03:31 PM   #6
1987SierraClassic
On my '87 4-spd, the backup light switch is screwed into the side of the gearbox underneath the truck.
1987SierraClassic is offline   Reply With Quote
