Old 09-10-2009, 07:30 AM   #1
dgas
73-87 Granny tranny ??
1982 3 speed w added low gear in a 1/2 ton , I am trying to remove this trans and am having trouble figuring out how to remove the shifter. I see two roll pins at 3 and 9 o'clock, but cannot figure out how to pull them as they do not go through.The whole truck project got delayed due to an emergency angioplasti, (had a couple chest pain incidents so I went in.) I should be in shape in a couple days to get back to it. Pulling the motor/trans is the is the first step now. It is ready to pull except that shifter and I do not have the means to drop it out the bottom.
1966 Chev LWB C20 PU
http://s41.photobucket.com/albums/e2...ev%20C20%20PU/
dgas is offline   Reply With Quote
Old 09-10-2009, 07:41 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: 73-87 Granny tranny ??
There is a stamped steel "cup" that captures the base of the shifter; it has slots that engage those roll pins. You should be able to grab the top of that cup with a pair of channellocks; push down while rotating counterclockwise and it should come loose. It is all spring loaded so once you clear the pins it should pop up.
Kinda like opening a bottle of aspirin (...only bigger...).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-10-2009, 07:42 AM   #3
Keith Seymore
PS - "granny tranny".... (lol)! I like it!
K
1979-1986
1986 - 2019
Old 09-10-2009, 07:53 AM   #4
Number21
Number21's Avatar
K
Yep, I just did exactly that on my 4 speed only in reverse. Tired of the shifter coming out while I was driving.
Number21 is offline   Reply With Quote
Old 09-10-2009, 07:55 AM   #5
dgas
We always called those super low gear trannys that,"slow as a granny " LOL thanks for the info i'll try that in a couple days.
