Old 09-10-2009, 11:08 AM   #1
rod86
great southern land
rod86's Avatar
vent window glass removal (from frame)
has anyone remover the piece of glass from the window frame on the vent windows? without smashing it obviously.. if so how did you do it?
cheers
rod
86 chevy c10 silverado
rod86 is offline   Reply With Quote
Old 09-10-2009, 02:00 PM   #2
nlped
nlped's Avatar
Re: vent window glass removal (from frame)
Yeah, I did it. It is a pain, but you just have to go really slow and gentle. I soaked the rubber "gasket" material that holds the glass into the frame with some WD40 and let it sit over night. Then I GENTLY pryed the glass out with a small flathead screwdriver and a pick tool. Hope this helps.
Cheers,
Ed
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-10-2009, 07:07 PM   #3
rod86
great southern land
rod86's Avatar
ok yea ill give it a try
rod
Old 09-11-2009, 04:32 AM   #4
westie 666
westie 666's Avatar
I did this also, i soaked the rubber with auto thinners, it melted into the rubber and i then pryed it out.
It came out very easy
77 Cheyenne no longer in bits
westie 666 is offline   Reply With Quote
