![]() Join Date: Jan 2008
6.0l wiring question
I'm wiring up my 6.0 and trying to figure out what I need on the harness and what I can do without. I'm running a 4L60E and I'm customizing a factory harness. I was wondering if anyone knew if I had to use the gear selector sensor (I guess thats what it is!) on the side of the transmission where the shift linkage mounts. Also if anyone has done this, do you know which sensors and pins the PCM can live without? Thanks
![]() 85 SWB 6.0 swap/heads/cam/pistons/headers/4L60E/3.73 posi/one piece windows/working towards air bags 04 Avalanche/9 inch lift/wheels 20x12 with 35 inch tires |
Re: 6.0l wiring question
yea the 4l60 uses the TCM (trans control module) without it no shifty.
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) Last edited by Cherub; 09-10-2009 at 12:59 PM. |
Thanks for the heads up! Did you do your own wiring or use a pre-made harness?
Next project: 1970 K10
This is what is left on mine after stripping out the unneeded stuff (2006 5.3/4L60E):
BARE WIRES: To tach To fuel pump relay control To brake light switch, cruise To brake switch, for TCC VSS, to speedo To MIL light 3 Red wires - 12v key-on 1 Pink wire - 12v battery 1 Purple wire - To starter solenoid CONNECTORS: Electric fans TAC module Wires (3) to cruise DS coil packs DS injectors Alternator Coolant temp sensor (front of left head, for PCM) Ground Starter solenoid Crank sensor Oil level switch (in oil pan) MAP sensor Passenger side O2 sensor, front MAF PS coil pack Ground PS Injectors Throttle body Knock sensor harness Oil PSI switch (behind intake manifold, for PCM) Cam sensor Ground Driver side O2 sensor, front Transmission, drivers side Transmission, VSS, tailhousing Transmission, passenger side
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 09-11-2009 at 11:37 AM. |
Thanks!
![]() Just curious but the "transmission, drivers side" is the park/neutral safety switch correct? And if so does yours have 1 plug or 2 on it?
Not sure on it's exact title, but mine has one plug on the drivers side to the module that surrounds the shift linkage.
I think it has something to do with telling the PCM what gear it's in too.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
Ok thanks! I've got an extra plug and was trying to find out where the other one went because the wiring diagram was kind of vague.
Since I just plugged it in tonight, I can tell you that my drivers front O2 sensor wires come out right next to the one that goes to the drivers side of the tranny. The O2 connector is a square shaped 4-pin.
I have a black connector with about 6 pins in it. My problem is that I have already taken all the looms and tape off the original harness and I'm just assuming thats where it came from because the wires are about the same length as the neutral safety switch and I don't have anything to plug it into!!!
Cody - I was just looking over some of my diagrams, and I see there is a 6-pin plug for the tranny that is the "Park/Neutral Switch". Keep in mind, this is for a 4L60E, but they might be the same.
This one lists the colors and functions as: Looking at the end of the plug, with the latch on top: (4 across the top, 3 across the bottom) A B C D G F E A Not used B Not used C Not used D Ground (probably black) E Park Signal (Green) F Park/Neutral Signal (Yellow) Hope this helps.
And its a black plug right? I'm running a built 4L60e behind the 6.0 so thats what I'm looking for, I'm sure. Thanks. Did you unhook your factory park/neutral safety switch in the column or do you have it wired up and both are used?
I don't have that particular plug on my harness, at least I don't have one that looks like the one on my diagram.
I never thought of that, both are used right now. I suppose I could disconnect the truck's switch.
#13 |
hey whats up. do you guys know where the crank position sensor is? either i im not looking in the right place or i just dont see it. im looking for it right under the crank pulley, is that where its supposed to be. its an 05 5.3
#14 |
Behind the starter, and slightly above it.
#15 |
yeah its kind of hard to see if you have the starter on.
#16 |
I was just wondering. Thanks
#17 |
cool tahnks, i didnt really know what each sensor looked like but i found them by the wire colors from the diagram, i wanted to find all the sensors before i took the harness off
