Old 09-10-2009, 02:40 PM   #1
arm51
beer me
arm51's Avatar
heads
im startin to save up some money for some heads im thinkin about gettin some edelbrock estreet, or should i get something else any opinions
1969 c10 currently on hold because of a darn f**d
1986 f150
1986 silverado-my dads truck that i'm fixin up
ill keep my freedom my guns my money my religion and you can keep your CHANGE-hank williams jr
arm51 is offline   Reply With Quote
Old 09-10-2009, 03:33 PM   #2
mplex2000
mplex2000's Avatar
Re: heads
Lots and lots of options out there. Honestly, there are two heads I would use. For a non all out motor, use the factory Vortec heads. I'd think you could find a clean set for pretty cheap. If you're doing a serious buildup, no reason not to use AFR.
mplex2000 is offline   Reply With Quote
Old 09-10-2009, 04:20 PM   #3
hayhauler71
hayhauler71's Avatar
Re: heads
I used the edelbrock performer rpm heads for 3 years now and no problems.
hayhauler71 is offline   Reply With Quote
Old 09-10-2009, 04:45 PM   #4
oldcarfart
Re: heads
I like their heads. make sure you get their recommended head gaskets because of the difference of expansion and contraction between the iron block and aluminum heads
oldcarfart is offline   Reply With Quote
Old 09-10-2009, 05:42 PM   #5
americanmusc1e
americanmusc1e's Avatar
Re: heads
X2
vortecs flow better than E-streets or Performers, unless your building something for 5500+rpm use, the vortecs are bout the best. (buy them from Jegs, Summit, or SDPC--don't buy them from a wrecking yard and have them redone, it will cost you more)
Other than Vortecs, use Performer RPM, Trick Flow or AFR.
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
