Old 09-10-2009, 03:04 PM   #1
Hair
Sealing Body Seams
I'm fixin to put seam sealer on my seams on the cab. I had to weld in new floor pans inner and outer rockers, floor supports, cab corners, etc.
At the bottom of the door jams you have about a 1/2" gap between the floor and the lip of your outer rocker. It's the lip that the door seals attach to. There is a seam there or a "crack", I guess you could call it, between the floor and the outer rocker panel. The floor is only attached to the outer rocker by 5 or 6 plug welds from the top side and a few stitch welds at the bottom of the rocker underneath.
Does this seam get sealed? It looks like it should be, but I don't remember seeing anything there, but then again, mine was rotted away... I think I'm going to seal it. Can't hurt...can it?
Hair is offline   Reply With Quote
Old 09-10-2009, 03:13 PM   #2
turp mcspray
turp mcspray's Avatar
Re: Sealing Body Seams
I would seal it. On mine I drilled a hole on each end (3/16" or so) so any water that might get in there will leave. I'm a firm believer in sealing any seam or overlap in sheetmetal that has the ability to hold moisture and start down that nasty road to rusting again. There is a lot of stuff that the factory didn't seal. If they lasted forever and never rusted, you wouldn't need to go back and buy another one now would you.LOL!
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
