Old 09-10-2009, 04:14 PM   #1
Oklahoma
Main bearing torque spec
Hey, does anyone know what the torque spec and sequence for a 69 350block with 2 bolt mains? I plan on removing the engine and dreplacing all the seals. Any suggestion on how to do this and perhaps keep it from leaking ever again I have a Fel pro gasket kit coming in and I want to do this right. I know to put a dab of RTV in the corners of the main gaskets, but anything else, or any little tricks you guys have would be greatly appreciated
Oklahoma is offline   Reply With Quote
Old 09-10-2009, 05:02 PM   #2
198plus
198plus's Avatar
Re: Main bearing torque spec
Maybe this link will help you........
http://boxwrench.net/specs/chevy_sb.htm
198plus is offline   Reply With Quote
Old 09-10-2009, 06:58 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
I have had great success with heavy valve covers, not stamped. I used gaskets that were rubber and had a metal core. Got them at the local speed shop.
Wish the old engines had O-rings like the LS series.....
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
