Old 09-10-2009, 05:16 PM   #1
mclairmo
Loose Rocker Arm
Pulled the valve covers off my truck's small block for the first time since I bought it and everything was very clean underneath but one rocker arm was a little bit loose and I could jiggle the push rod a little. All the others were not loose. I assume this is NOT normal as there should be zero lash correct? Should I just tighten that one rocker arm up till no more jiggling and then go 1/4 turn more?
mclairmo is offline   Reply With Quote
Old 09-10-2009, 09:30 PM   #2
hayhauler71
hayhauler71's Avatar
Re: Loose Rocker Arm
I would check a few things before adjusting that rocker arm. 1 make sure the rocker arm stud is not pulling out of the cylinder head 2 make sure the rocker arm ball did not wear through the rocker arm. 3 check make sure the push rod is not bent. If all looks good i would adjust all the rockers according to the cam manufacturer or service manual.
hayhauler71 is offline   Reply With Quote
Old 09-11-2009, 04:37 AM   #3
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Also I would check for a collapsed tappet.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 09-11-2009, 10:47 AM   #4
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
cam lobe may be going away
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
