Old 09-10-2009, 05:55 PM   #1
90\87Formula
90\87Formula's Avatar
Changing rearends
I'm finally changing my 69 Fleetside from 6 lugs to 5 lugs. It's a 1/2 ton with coil springs.
Do I need to replace the U-bolts on the trailing arms or can I just use the old ones? If I need to replace them, where do you recommend buying them?
Robert
Member 1532
90\87Formula is offline   Reply With Quote
Old 09-10-2009, 06:09 PM   #2
BCOWANWHEELS
Re: Changing rearends
Rather than going to all that trouble you could just pull your axle shafts out and send them to moser eng. In portland indiana and have them re-drilled to 5x5 bolt pattern. There very inexpensive to redrill, use your old wheel studs too. Sure would save alot of time and money. Then use 5 lug drums. Backing plates are the same.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 09-10-2009, 06:16 PM   #3
90\87Formula
I bought a complete replacement rearend today.
Robert
Member 1532
Old 09-10-2009, 09:58 PM   #4
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I need to do this swap also..
is it just bolt in or do I need to readjust some kind of angle...pinion angle maybe?
Do I just bolt a 71 72 rearend in...or is there some adjustintg?
John
1999 Toyota Tacoma 4x4
Old 09-11-2009, 04:35 AM   #5
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
70 was the year that GM changed axle lengths. If your putting 71-72 axles on a 69 you should measure from the flange to the tip of the splines and get axles that are the same length.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 09-11-2009, 07:44 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You guys are making this harder than it is. Unbolt the 6 lug rearend and bolt the 5 lug rearend in place. Nothing fancy needed. It's an hour job.
Old 09-11-2009, 08:58 AM   #7
cdowns
cdowns's Avatar
i suggest getting new ubolts// local auto parts or spring store is where to get them
Old 09-11-2009, 10:45 AM   #8
90\87Formula
Thank you for answering my original question.
Robert
Member 1532
Old 09-11-2009, 10:48 AM   #9
90\87Formula
Thanks Kevin. I was pretty sure it was a direct bolt-in. I just wasn't sure about replacing the ubolts.
Robert
Member 1532
Old 09-11-2009, 11:31 AM   #10
Keller
Keller's Avatar
Hey 90/87 Formula.. I know this is a little off topic but does your name refer to the legendary Pontiac Firebird Formula? I had a 90 Formula 350 that I learned how to wrench on.
Keller is offline   Reply With Quote
Old 09-11-2009, 05:00 PM   #11
oldblue1968chevy
thats what i thought, just wanted to makesure, thanks TXfirefighter
John
Old 09-13-2009, 06:37 PM   #12
90\87Formula
Yep. The car started as a 90 coupe with the 3.1L MPFI. The 3.1 motor got trashed and I bought an 87 Formula rustbucket. I moved EVERYTHING that could be unbolted from the Formula to the coupe, thus 90/87Formula.
Robert
Member 1532
