Old 09-10-2009, 10:11 PM   #1
zipgun
ZIPGUN
zipgun's Avatar
Rear Differential ? with 3.42 gears
I was told that if I am running 33" tires on 15 inch rims on my 90 burb that it would destroy my rear differential. I did have one go bad but it was due to the nut that held the companion flange to the differential came loose and the crush washer was missing. (I think someone had already been into it) Anyway I am looking for a new axle assembly currently. Just wondering if I maintain the 33's am I going to have the same trouble ??
zipgun is offline   Reply With Quote
Old 09-11-2009, 08:56 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Rear Differential ? with 3.42 gears
I'm not sure why 33" tires would destroy your dif unless they are talking about 4 wheeling.
Regardless, if I were running 33's I would want 3.73 gears as a minimium. It would probably be much better with 4.10's.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-11-2009, 10:41 PM   #3
tvblazer78
Low & Fast!
tvblazer78's Avatar
I have had lot's of trucks with 33" and 35" and have not see this before.
tvblazer78 is offline   Reply With Quote
Old 09-16-2009, 01:19 PM   #4
justpball
justpball's Avatar
i am running 36 with 3.42s but I found a buddy that had a wrecked 2002 truck and swapped the whole rear so I have disk in the back
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
