09-10-2009, 10:46 PM | #1 |
Rusty Bolts
What are some technq.'s to remove stepside? Going to be taking them off this weekend. Wanna see if you guys have any tips i can use if i run into problems
Learning as I go! ------------------------------------- |
09-10-2009, 10:50 PM | #2 |
Nothing to see here.....
Re: Rusty Bolts
are you taking the bed off the frame or the fenders and steps off the bed?
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
09-10-2009, 10:54 PM | #3 |
Re: Rusty Bolts
I like to use a sledge hammer for the bigger jobs.
If you can't fix it with a hammer then you have an electrical problem. |
09-10-2009, 10:57 PM | #4 |
Re: Rusty Bolts
I'm hopin to keep the bed on the frame.
09-10-2009, 11:42 PM | #5 |
Re: Rusty Bolts
sometimes liquid penetrant will work. you may have to cut the 8 bolts that connect the bed to the frame off with an angle grinder.
09-10-2009, 11:48 PM | #6 |
Re: Rusty Bolts
09-11-2009, 12:53 AM | #7 |
Re: Rusty Bolts
Try tightening the nuts til the bolts shear...
09-11-2009, 09:29 PM | #8 |
Re: Rusty Bolts
If your are trying to remove bolts that go into a threaded hole on the other side and want to avoid twisting them off, get an acetylene torch on low-med heat and heat the heads red hot, doesn't take very long. Let it cool completely and they will spin right out with a ratchet. Note, propane or mapp gas torch will not work, not hot enough.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
09-11-2009, 10:43 PM | #9 |
Re: Rusty Bolts
well darn i was going to use the MAPP gas torch too. I guess i will use that for fixing the oil canning on the top side of the fenders. I think i will just cut em off.
