09-11-2009, 07:22 AM | #1 |
Rear end yoke interchange??
To start off I am putting a LT 4.3L V8 with a 4L60-E trans In my 72 short step that orig had a 307, I do not know the trans and the only thing I know about the rear is it's a 12 bolt. I'm having trouble with the driveshaft from the new engine fitting my old rear end. The car that the engi e came out of has a 10 bolt rear end. The new driveshafts u joint is both too wide to fit the trucks yoke and the caps are a little bit bigger than the old ones. So what I'm basically asking is what and will any other chevy rear end yokes fit this trucks. It will save me the trouble of taking the old yoke to a machine shop to bring it down
Last edited by Terakilla; 09-11-2009 at 07:24 AM. Reason: iPhone sucks at spelling |
09-11-2009, 07:36 AM | #2 |
Watch out for your cornhole !
Re: Rear end yoke interchange??
You need what is called a "conversion u joint". The parts stores stock them. It's intended to do exactly what you need without modifying anything else.
http://www.neapco.com/n_products-catalogs.php Click on the dimensional reference guide and go to page 5 for specifics. If you get lucky enough to get a real parts person at your store, they can look it up for you.
09-11-2009, 07:43 AM | #3 |
Wow you are freaking awesome man, i never would have thought of that, regretably I can't view the docs on this stupid iphone i'm using but ill get to a comp asap. Thanks for the quick reply, you may have saved me a lot of worry.
09-11-2009, 09:13 AM | #4 |
Great link TX!!!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
