Old 09-11-2009, 07:34 AM   #1
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Using a Camaro Tach in our Gauge Clusters
Back some time ago (07/2007) Board Member "Gringoloco" did a write up on installing and using a Camaro Tach in our Gauge Cluster (see his build link below). My question is, has any other board member done this (pics please) and were any of the other gauges from the Camaro Cluster used. Looks like the Camaro Tach was from a 70-81.
http://67-72chevytrucks.com/vboard/s...d.php?t=251017
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 09-11-2009, 08:48 AM   #2
myoldchevytruck
Re: Using a Camaro Tach in our Gauge Clusters
Any Suggestions?
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 09-11-2009, 09:37 AM   #3
BarryB
BarryB's Avatar
I remember the write up, had me wanting to do mine, But sorry never got around to it. So here is a bump maybe we can catch somebody that did do it.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 09-11-2009, 09:38 AM   #4
2tons of fun
how well has it held up, would you have done anything different now?
2tons of fun is offline   Reply With Quote
Old 09-11-2009, 10:12 AM   #5
myoldchevytruck
Have not done anything yet, I'm gonna look into it more. When I get the Cluster finished, I'll post pics.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 09-11-2009, 11:33 AM   #6
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
I am working on one right now. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 09-11-2009, 11:49 AM   #7
myoldchevytruck
sweet, is it in deed the 70-81 instrument cluster from the camaro. are you using the other gauges? would like to see pics when ur done
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 09-11-2009, 01:20 PM   #8
smoky02
Location: Sunny, Florida, some might call it South Alabama
I had never seen that before, but i looks very good. I will have to make sure to save that link.
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 09-11-2009, 03:08 PM   #9
71blksuper4x4
SWB 4x4 Collector
I will post pics soon, putting some finishing touches on it, I don't know if I should put a quartz clock in it or not. I am trying to make it look more original than any other one I have ever seen. I plan on selling it on the board here in the next week or so. Trevor
TREVOR
Old 09-11-2009, 03:11 PM   #10
71blksuper4x4
SWB 4x4 Collector
yes, I used a cluster out of a 70-81 camaro. The tachs are different through the years, some are better choices than others, but I can't tell you what years are better than others. You can use the clocks out of them as well, but I hear that the quartz clocks out of 81-87 pickups is better to use. Trevor
TREVOR
Old 09-11-2009, 03:29 PM   #11
myoldchevytruck
Trevor,
Thanks for the info. I'll be getting my Camaro Instumment Cluster here in a few weeks when I go to Jersey. This one Red Lines at 4500 and goes to 7000 RPM. It should look real cool in there. I would like to use most or all of the gauges. Looking forward to seeing pics of your gauges.
Thanks Again
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 09-11-2009, 11:48 PM   #12
aboyer
Adam B
I did this a couple months ago and it was fairly easy to do. It did take some fine tuning of the back metal part of the dash to clean everything up. It looks great now and very factory.
I did mine on a '68 Chevy truck, where you have the turn signal arrows. I used plastic cleaner, 2000 grit sandpaper and small bit of water to remove the turn signal arrows.
I don't have the turn signal arrows, but I just try to remember if I turned the turnsignal on/off.
I would highly recommend this. They sell the tachs on e-bay for $10-$40.
Adam
--if i remember, i will take some pictures to post.
aboyer is offline   Reply With Quote
Old 09-12-2009, 06:03 AM   #13
myoldchevytruck
Adam
Adam,
Thanks for the info. Pictures would be great.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 09-13-2009, 05:05 PM   #14
profe56
Great Job¡¡¡ GRINGOLOCO found this post and you give me ideas because I already bougth an used gauge cluster and I was thinking to do what you did, so now I need to buy the tach., basically you did the job for many of Us.
Thank you
profe56 is offline   Reply With Quote
Old 09-13-2009, 06:29 PM   #15
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
You can use the 130mph speedo or 150mph Z28.
Z28 also had a 8K tach!
Notice if you take off the stock gas gauge markings you can redo them inside the gauge and they match the size of the speedo. See pics.
PICKMUP is offline   Reply With Quote
Old 09-13-2009, 06:34 PM   #16
myoldchevytruck
frank, what year z28?
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 09-13-2009, 08:48 PM   #17
purewhitemp5
From what I have seen on ebay the Z28 tach and speedo fetch a pretty penny.
purewhitemp5 is offline   Reply With Quote
Old 09-13-2009, 09:01 PM   #18
myoldchevytruck
I have the 70-81 Camaro Instrument Panel (I'll actually be picking it up next week) and want to use all of the gauges from it for my C-10 Bezel. According to PICKMUP the Z-28 Panel my fit a bit better. Like I said I get it next week and I'll be out of town for a few weeks. As soon as I get it done, I'll post pictures
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 10-05-2009, 10:43 PM   #19
aboyer
Adam B
Sorry for the delay in posting the picture.
Here is a picture of my gauge cluster. The tach is from camaro,
70-82 I think??
Adam
Old 10-06-2009, 06:48 AM   #20
myoldchevytruck
70-82 I think??
Adam
Wow Adam! That tach looks really good in our gauge bezel. Was there allot of fab work to fit it? If so, please share any info as I am really interested in fitting one for my 69' Stepside. Thanks for the picture.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 10-06-2009, 09:04 AM   #21
nicolas72gmc
nicolas72gmc's Avatar
subscribing!
Nick
"Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson
1968, GMC, SWB, Project
1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components.
1972, C/10, LWB, 350 vortec, th350
nicolas72gmc is offline   Reply With Quote
Old 10-06-2009, 10:15 AM   #22
big_al_71
big_al_71's Avatar
This is one mod that I have gone back and forward 100 times between just doing all my gauges with a new bezel to autometers or just keeping mine and adding the camaro tach...so I am suscribing as well..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-06-2009, 10:57 AM   #23
highperf4x4
subscribed.
I wonder what the black tach would look like with all the rest of my gauges being white............
highperf4x4 is offline   Reply With Quote
Old 10-06-2009, 11:11 AM   #24
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I'm in??? now what did I do with that spare truck dash?? I need a fuel guage needle??
one questoin when you swapped needles how did you get it where it belongs in relation to the one you took off??
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 10-06-2009, 12:26 PM   #25
71blksuper4x4
SWB 4x4 Collector
Here's one I have been working on:
TREVOR
