Old 09-11-2009, 09:58 AM   #1
6772owner
Gearhead
6772owner's Avatar
67' K10 front srings
Hello everyone, I spend most of my time in teh 2ws forums, but I am in need of assistance with my 67' K10. I have front leaf springs for 73+ trucks and would like to put them on the 67' I have run into a few issues, the springs are physically longer and im not sure the center pin in is the same relation to stock springs. (Ok I mean will the front axle still be centered the same in the wheel well?) Anyone tried this before? Do I just need to get 67' specific front springs? Thank you for any help you can provide.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 09-11-2009, 10:27 AM   #2
70 beast
Certified Hobbiest
70 beast's Avatar
Re: 67' K10 front srings
not sure on the center pin but those springs will max out your shackle and rest up against the frame.
a longer shackle might work but im not 100 % sure.
70 beast is offline   Reply With Quote
Old 09-11-2009, 10:39 AM   #3
6772owner
Gearhead
6772owner's Avatar
Ok thanks for the info, I attempted to install one spring last night and it did hit the frame, I was worried that a longer shackle would be at too steep of an angle.
Old 09-11-2009, 03:07 PM   #4
topdog
topdog's Avatar
You will have to relocate the mounting points. You might check out www.diy4x.com The have a kit just for that, # FGB52
  • 67 C10 swb,fleet,small window,ps,pb,350,350.
  • 01 Dakota RT 5.9,3.92 posi.
  • 64 vette coupe 327,350 turbo,posi.
  • 68 K-20 lwb,fleet,327,350
topdog is offline   Reply With Quote
Old 09-11-2009, 03:12 PM   #5
6772owner
Gearhead
6772owner's Avatar
Cool thank you, I had no idea
Old 09-11-2009, 04:33 PM   #6
6772owner
Gearhead
6772owner's Avatar
Ok I looked at that kit but i am still a little confused, I do not want to use the rear springs for the 73+ only the front ones, are they 52" as well? I thought that only the rear was 52" and the front were shorter?? Am I mistaken here?
Old 09-11-2009, 05:24 PM   #7
70 beast
Certified Hobbiest
70 beast's Avatar
no. the front measure i believe 47 ish?
i also beilieve the diy4x kits has holes for diffrent length springs also so you may be able to use that kit.
they also offer a weldon front perch that you can weld or bolt (drill your own holes) that might work better
Old 09-11-2009, 05:49 PM   #8
topdog
topdog's Avatar
My bad, most people ask about 52's and that kit just came to mind. If you can measure bracket locations from the donor truck that would help you a lot. Like 70 Beast said diy4x has other parts that may help you out.
Old 09-11-2009, 05:51 PM   #9
6772owner
Gearhead
6772owner's Avatar
Ok thanks for the info guys
